Complete brake line kits? 1987 Iroc
Old Mar 14, 2016 | 07:25 PM
AmpleUnicorn88's Avatar
Engine: 305 TBI/305 TPI
Transmission: World Class T5/missing
Axle/Gears: 3.08/G92 3.45 posi
What I am looking for is a link or reference to somewhere that I can find a complete braided stainless brake line kit. Russel is the brand I went with on my 88 but it wasn't a kit. I went to a local speed shop and picked out the lines and fittings to match the stock hard lines. I ended up replacing the entire hardline for the driver front and then replaced both rubber lines with the braided ones. What I'm looking to do with the iroc is replace everything- the front and rear brake lines with the braided lines. I know it's possible because the speed shop by me has all different lengths and fittings and that's how I did it before, however I'd prefer to buy a kit because I'm assuming it will be cheaper to do it that way. Summit has a Russell kit that has 4 lines in it which look like the replacement for the front rubber ones, and I'm not sure what the 2 rear ones are or how they work. I removed the rear end myself but I can't remember how the brake line worked for the rear because I had to cut it to get it out. This whole car sat for years and a lot of things are broken/rusted. I'd rather just replace all the brake components 100% because it isn't a risk worth taking when driving.
Worst case scenario I will go to the local shop and just measure the lengths I need and build my own lines again, I was just hoping to save some money this time.
Old Mar 15, 2016 | 03:06 AM
fokeyman's Avatar
Car: 89 IROC
Engine: l98 350 TPI
Axle/Gears: 373s
Re: Complete brake line kits? 1987 Iroc
Have you tried rockauto? They sell braided hoses. IIRC there might be actually 5 lines that can be replaced.
edit: Woops, not RA, I meant Oreillys ($156), they have the braided kits.
Old Mar 15, 2016 | 07:04 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Two front and two rear lines (one at the diff and one at the pass side caliper).
JamesC
Fireball
Apr 29, 2016 12:15 PM
Mattkovitch
Apr 1, 2016 04:08 PM
Eric-86sc
Exterior Parts for Sale
Mar 19, 2016 06:01 AM
redwolf7374
Feb 22, 2016 07:42 PM
'91CamaroRS
Brakes
Feb 15, 2016 11:56 AM
