Best 4 piston front brakes
Old Apr 6, 2016 | 01:20 PM
Crossfire1983's Avatar
Car: 1983 Chevrolet Camaro Z28
Engine: LS3
Transmission: Tick TR6060 w/ Mantic 9000 clutch
Axle/Gears: Strange S60 w/ 3.73 True Trac
Looking for something that's either a 12 or 13 inch rotor. What's worked well for you guys?
Old Apr 6, 2016 | 08:50 PM
cosmick's Avatar
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
Re: Best 4 piston front brakes
What's this obsession with best? Everyone wanting a best caliper, a best camshaft, etc. Generally, even if there is one, after factoring your goals, your budget, your application, and your skills, it's unlikely you'll find it. Good enough seems like settling for inferiority, but that's not necessarily so.
Old Apr 8, 2016 | 06:58 AM
esc's Avatar
esc
Car: '82 Camaro 11.7@121
Engine: 377
Transmission: 400
Axle/Gears: Dana 44 / 3.31:1
There are lots of options out there.
Like cosmic said "best" for you may not be best for everyone else. A reasonable recommendation would require more information from you. Budget is important, but what wheels it needs to fit inside of would be my first question.
I just finished a brake upgrade on my car and my first question was "What will fit?" It turns out that I could not get what I wanted inside of the wheels I was using, so I had to get different wheels. So that brings us back around to budget. It is all an interrelated compromise.
For instance, "Best" for me included having the option to buy rotors and pads from a local source. If that isn't important to you, my "Best" may not be your "Best."
So give some thought to what is important to you, what wheels you want to run and what your budget is. With that info some here may be able to make a recommendation as to what they think best fits YOUR needs.
Old Apr 8, 2016 | 07:05 AM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
If you search on here you will find lots of options, C5, C6 vette is probably what you are looking for unless you want to spend big money and go brembo or baer
Old Apr 10, 2016 | 05:16 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
$750..shop a bit
small mod to spendles..then bolt on
89TA WS6
Apr 20, 2016 09:37 AM
jimmydz28
Apr 3, 2016 02:20 PM
Bryanm254
Mar 31, 2016 06:48 PM
Vinscully50
Mar 15, 2016 03:25 AM
Relik
Mar 11, 2016 03:06 PM
