Moser 9" Big Ford drum brakes
Old Apr 13, 2016 | 03:33 PM
Teds92RS's Avatar
Car: 1989 Camaro IROC-Z
Engine: Lt1
Axle/Gears: Quick performance 9" 4.11
Moving in the opposite direction here, but I got a great deal on a rebuilt 9" that was previously installed on a thirdgen so it has the proper steel and e-brake lines for a direct bolt in. My car came factory with PBR disc brakes. The plan is to eventually buy a big Ford 9" disc conversion but for now, how will the rear brakes react to a factory disc/disc proportioning valve? Any experience? I tried searching but not coming up with what I'm looking for. Trying to decide if it's necessary to change the prop. valve or install an inline adjustable prop. valve.
Old Apr 13, 2016 | 03:39 PM
Rkn1990's Avatar
Car: 1990 bandit II formula
Engine: 355/9.25:1/6psi
Transmission: Tko
Axle/Gears: 9 bolt with 3.70s
Re: Moser 9" Big Ford drum brakes
I'm sure others can argue against me here, but I've had an lsx rear in my car with dual piston calipers in it, back to a drum brake 10 bolt, to a 9 bolt with lt1 disc brakes, and I've never changed the proportioning valve.....got to a point where I was breaking so many 10 bolts that I just tossed whatever junkyard rear I could find in it to keep it on the road. Never had an issue.....put it in and see how it stops, you probably won't have a problem, especially if it's temporary and it gets ya on the road for hot rod season
Old Apr 14, 2016 | 10:08 PM
Teds92RS's Avatar
Engine: Lt1
Sounds good to me!
turd_gen
Brakes
May 7, 2016 01:28 PM
dpmalibu
19
May 4, 2016 04:06 PM
Rkn1990
Apr 18, 2016 06:58 AM
1992rs/ss
Apr 17, 2016 01:51 PM
ken3983
Apr 13, 2016 11:43 AM
