Do you have to push the brake to start the 1986 Trans Am
Old Aug 11, 2016 | 11:15 PM
Sutliff01's Avatar
Car: 1986 Trans Am
I feel really stupid asking this question but do you have to push the brakes to start the 1986 trans am. I recently got the car from my mother and I want to try and get it up and running. Every time I try to start the car it makes a click noise and a red light that says brake pops up and I can't start the car
Old Aug 12, 2016 | 06:22 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Do you have to push the brake to start the 1986 Trans Am
No.
Old Aug 12, 2016 | 09:10 AM
jkris53406's Avatar
Car: 87 Formula, 91 Trans Am
Engine: 355 tpi, 305tpi
Transmission: 700r4, 700r4
Is the battery dead?
Old Aug 12, 2016 | 12:48 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
No, but it's a good habit.
The battery light coming on at key-up is normal, and show's you have a little battery voltage, but perhaps not enough to crank the engine (causing a clicking noise from the start motor solenoid).
Old Aug 13, 2016 | 03:20 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
hook up a battery charger..
Old Aug 13, 2016 | 02:10 PM
Night rider327's Avatar
Car: 1988 Camaro
No, you Don't have to press brake to crank. You have a weak battery or a poor/bad cable connection. Wiggle the terminals at the battery and see if that helps. Take cables off battery and clean terminals and post. Put a battery charger on battery.
Old Aug 14, 2016 | 08:56 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Unscrew & re-install the Ground wire leading away from the battery ternimal and gets screwed to the body right next to the battery,.........
Michael Harding
Jan 12, 2019 11:11 PM
jakemack96
Mar 29, 2016 09:23 AM
Vinscully50
Mar 15, 2016 03:25 AM
CrazyHawaiian
Aftermarket Product Review
Apr 8, 2001 08:00 AM
Slow-LG4
Oct 31, 2000 10:19 PM
