Rear Disc Conversion Kits?
Old Sep 19, 2016 | 11:15 AM
jjohnston's Avatar
Car: 91 Camaro RS
Is there a kit to convert the stock rear drum brakes on a 91 RS to rear disc?
I was looking at the kit below but didn't know if it was built for this type of conversion or not...
http://www.jegs.com/i/Right-Stuff/965/AFXRD78/10002/-1
Old Sep 19, 2016 | 11:24 AM
jjohnston's Avatar
Car: 91 Camaro RS
Re: Rear Disc Conversion Kits?
Or would I need something more like this?
http://www.jegs.com/i/SSBC/884/A125-46/10002/-1
Old Sep 19, 2016 | 01:13 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
http://www.flynbye.com/catalog/i10.html
Check the above company for various kits.
JamesC
Old Sep 19, 2016 | 02:29 PM
BovineZro's Avatar
Car: '91 Camaro Z28
Engine: L31 5.7
Axle/Gears: 10 bolt, 3.73
I installed this kit; pretty straightforward, although it does NOT come with the correct ebrake cables (sourced some through Hawks). I have a 91 Z28, so this should work fine for your 91 RS. It does fit under the stock wheels.
In the interest of full disclosure, I've driven maybe 5 miles with these brakes.
I have a few pictures in my build thread if you are interested: https://www.thirdgen.org/forums/memb...z28-build.html
Old Sep 19, 2016 | 02:33 PM
BOTTLEDZ28's Avatar
Transmission: A4
JamesC
Is he still doing the brake conversion parts? I heard he was pretty backed logged.
Old Sep 20, 2016 | 07:24 AM
Necron's Avatar
Car: 2002 Camaro SS
Engine: Built LS
I went through http://bigbrakeupgrade.com/ for my fronts. Very fast and and great quality.
Old Sep 20, 2016 | 07:29 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
I would stick with the 89-97 style aluminum rear caliper unless it doesn't fit under the 15" wheels.
(I had them fit with my Weld wheels)
Old Sep 20, 2016 | 09:58 AM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
Somebody did a write up for the LS1 (4th gen) disc swap using used parts.
https://www.thirdgen.org/ls1reardisc/
I was looking into this as something else to do to my car over the winter. I priced out the parts (new) just to try and get a comparison on used. This is what I came up with.
ACDelco 10444626 GM Original Equipment Rear Driver Side Disc Brake Caliper Mounting Plate with Parking Brake Shoe
Amazon Prime- $82.34
ACDelco 10444624 GM Original Equipment Rear Driver Side Disc Brake Caliper Mount Plate Assembly
Amazon Prime - $107.40
Power Stop KC156826 Z26 Extreme Street Warrior Pads/Rotors/Calipers
Rock Auto - $271.99
WAGNER BC140184 or alt p/n F140184 Emergency Brake Cable
Rock Auto - $14.57 x 2
LS1 Rear axle and braided flex line kit
Flynbye.com - $130.00
Total $620.00
Old Sep 20, 2016 | 11:56 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Pm Sent:
Old Sep 23, 2016 | 03:25 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
there is a set on ebay for cheap
http://www.ebay.com/itm/82-92-CAMARO...JXxNCi&vxp=mtr
padak
Nov 16, 2016 04:58 PM
Truckin1999
Sep 30, 2016 08:10 PM
87zz28
Sep 19, 2016 07:28 PM
IROCZ1989
Brakes
Sep 16, 2016 01:44 PM
hub91z28
Sep 14, 2016 03:06 PM
