brake upgrade
Old Apr 19, 2017 | 07:01 PM
83sportcamaro's Avatar
Car: camaro
Engine: chevy small block 350
Transmission: 350th
brake upgrade
just did conversion from stock drum to disc
the problem is i have to step on the brake all the way down for my car to stop
trying to see if i have to change master cylinder or booster brake
the car i have is 1983 camaro sport
Old Apr 19, 2017 | 10:54 PM
brettr81's Avatar
Car: 91 Firebird
Re: brake upgrade
Need to change the proportioning valve too.
Old Apr 20, 2017 | 07:44 AM
BOTTLEDZ28's Avatar
Transmission: A4
Re: brake upgrade
You can either change the entire valve or just replace the spring inside the stock valve you have now. Or, get an aftermarket adjustable valve that goes inline. There is a thread here called Cheap Proportioning Valve upgrade. Read through it. It has a lot of good info in regards to the spring change. It takes 5 minutes to change the spring. You will need to rebleed your brakes.
articwhiteZ
Oct 5, 2016 07:37 PM
RABMAN
Sep 25, 2016 10:44 AM
BlackMamba
Brakes
Sep 24, 2016 10:42 PM
KCobain147
Brakes
Sep 14, 2016 06:31 PM
dbrochard
Sep 11, 2016 04:02 PM
