Rear Drum removal...
Car: 91 Z28 Coupe
I need to change my brake wheel cylinder, which is a PITA enough. But I am running into prob removing the drum. I can get it to wiggle off about 1/2", and then it stops. It seems to be catching near the 12 oclock position. E-brake is off, even took the car for a spin, putting in foward and reverse to try to break it free. Even took the route of a BF hammer. Still no luck. Missing something?
91Z, 305 TPI, rear drums(obviouslly)
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: Rear Drum removal...
I had the same problem. Had to use a piece of 2x4 and smack it with a big hammer against the drum all around the back edge until it finally came off.
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
Turn the adjusters down through the holes in the backing plate. It sounds like your brake shoes are stuck in a groove in the drum, or that the lip of rust is very steep and the shoes are keeping it from sliding off.
My adjuster was seized, which is why I had to use brute force...
Car: 89 Camaro
dpmalibu
May 17, 2010 07:59 PM
dpmalibu
Jan 29, 2010 10:53 AM
