Brakes vac pump question.
Old Mar 29, 2019 | 07:48 AM
Ronny's Avatar
I instald one due to 10 in of vac on new motor and cam. 236/242 @.05 112 lsa and 396 SB. I was told I need a check valve installed. Pump is in and works s well. pulls 16-20. How is valve plumbed in. Right now pump is pulling only brake boost. safety issues in future that way.
Ronny
Old Mar 29, 2019 | 04:20 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Brakes vac pump question.
The factory booster has a check valve as the Inlet fitting. That's the only one you need. Maybe I'm not understanding you correctly? Your post is a little hard to read
iroc stangs
Brakes
Mar 30, 2019 09:15 AM
MIKE 1985
Carburetors
Feb 4, 2004 11:29 AM
jon_volk
Nov 3, 2003 11:52 AM
GTA88
Carburetors
Apr 15, 2001 09:04 AM
gruveb
Mar 13, 2001 07:51 PM
