Can Vac Pump be used as as Vac Guage ??
Old Apr 11, 2001 | 10:55 AM
GTA88's Avatar
I want to buy a hand vacuum pump and also a vacuum guage. These things aren't as cheap as I thought they would be. :rolleyes
I noticed the hand pump has a vacuum guage on it. It's the pump with the reservoir attached to it for bleeding brakes. Is there some way I can make this or some other hand pump double as a vacuum guage, so I can use it to create a certain vacuum, and also to measure existing vacuum at vac hoses ?
88 GTA Charcoal Grey Bone Stock except for loose muffler which makes it a bit louder than normal.
Old Apr 11, 2001 | 11:12 AM
Damon's Avatar
I bought a hand vacuum pump at Pep Boys for $15. Had the vacuum guage mounted on the front of the pump cylinder and a neat little tire-style valve so it will hold the vacuum reading until you release it.
Old Apr 11, 2001 | 12:10 PM
GTA88's Avatar
Thanks for the lead. $15 sounds more reasonable than $34, which is what a pump cost at Advance Auto.
But are you able to hook a vac line up to the port on the pump and get a reading on the dial ?? In other words, can you get the pump to function as a regular vacuum guage ??
Old Apr 12, 2001 | 05:29 PM
The ODB's Avatar
Sears sells a very nice pump for $15
Old Apr 13, 2001 | 02:42 PM
GTA88's Avatar
ODB, Thanks. I'll check it out.
Old Apr 15, 2001 | 09:04 AM
GTA88's Avatar
And the answer is.... YES. I got the MightyVac hand pump, which claims it can be used as a passive vac guage also ! $25 at Autozone. The brand is OEM on the package, but MightyVac is printed on the pump.
83 Crossfire TA
Jan 3, 2016 01:26 PM
Gunsbee
Sep 7, 2015 07:10 PM
andy74
Sep 3, 2015 08:41 AM
RyanJB
Sep 2, 2015 01:27 PM
