Scored a 1le kit on ebay
Old Apr 1, 2019 | 11:18 AM
nbressette's Avatar
Full 1le front brake setup including calipers, brackets, and spindles for only $250!
Can anyone recommend a place I can send the calipers off to be rebuilt and powder coated?
Old Apr 1, 2019 | 01:26 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: Scored a 1le kit on ebay
I would just pull the pistons out yourself, clean them and paint them. PC will eventually peel, it's not the miracle coating everyone makes it out to be. At least with paint you can touch it up.
Old Apr 1, 2019 | 02:07 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Killer score there!
Clean with a acid and plastic brush then rinse really well. That will bring back the aluminum look and no paint helps them dump heat faster.
Old Apr 1, 2019 | 04:27 PM
Abubaca's Avatar
I've had real good results with the Duplicolor paint kit. Gotta get the brush on though, no spray.
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Wow, what a score!
Old Apr 1, 2019 | 05:53 PM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
I think Rock Auto has a rebuild service. So does Cardone. Personally, I'd do it myself or find someone local so you can keep an eye on it. would suck to lose it in the mail.
Old Apr 1, 2019 | 08:44 PM
Zach/90\irocZ's Avatar
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
Why not rebuild yourself
Wirebrush will do the trick
G2 is very good last very long but time consuming
duplicolor/vht is close to had good results as well more prep needed
but chips easy clear yellows over time and brake fluid eats it easy
I also feel depending on color stains easier and fades as well
But Best result have been
use etch primer then vht base then 2k high gloss clear
can get on amazon has hardner so won’t yellow etc
Old Apr 1, 2019 | 09:24 PM
Drew's Avatar
Rustoleum works shockingly good for calipers. These calipers brand F calipers on my super beater still look just as rediculous now as they did in 2008ish.
Duplicolor Engine Enamel'd these -
Old Apr 2, 2019 | 09:57 AM
Engine: 305 to 350
Axle/Gears: 10 Bolt
Prime VHT and VHT Clear over top
Baked it in the oven as well
Another car I did with 2k clear a lot more glossy
Mark_ZZ3
Jun 16, 2003 10:16 AM
AJ_92RS
Nov 20, 2002 12:14 PM
1986CamaroSC
Nov 19, 2002 01:29 PM
BretD 88GTA
Southern California Area
Mar 21, 2002 12:50 PM
