Emergency brake cable
Old Jul 29, 2019 | 05:48 AM
RedZ377's Avatar
Car: 1984 Camaro
Engine: 377 SBC
Transmission: Tremec 5 speed
Axle/Gears: Strange engineering, 4.56 gears
Does anyone know what brake E brake cables I need? I have a 1984 Camaro with a Strange 12 bolt rear that came with 1LE disc brakes but I don't know what cables to use. Thanks.
Old Jul 29, 2019 | 02:51 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Re: Emergency brake cable
I could be wrong but the 1le cable should work as long as the brackets and backing plates etc on the 12bolt are the same as it was on the 10 bolt.
Old Jul 29, 2019 | 04:12 PM
RedZ377's Avatar
Car: 1984 Camaro
Engine: 377 SBC
Ok thanks, I will check that.
Old Jul 31, 2019 | 04:23 PM
Aviator is right. The PB brackets on that brake system bolt onto the calipers... on my 83 w 90something PBRs, I used the 90something rear cables, and hooked em right up to the center thing in the tunnel with the 83 front cable, and they worked perfect. Yours should be the same. Piece o cake.
net_coma
Exterior Parts Wanted
Apr 19, 2007 08:59 AM
Mike1990Camaro
Brakes
Mar 4, 2007 05:29 AM
Mike1990Camaro
Aftermarket Product Review
Mar 4, 2007 01:51 AM
wm_sorg
Jul 31, 2003 09:13 PM
