Emergency brake cable solution for 4th gen rear swap
Old Jul 21, 2003 | 10:21 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
Hi guys,
I searched all of the old posts and can not find anything other than fabricated solutions.
Am I not mistaken that there was a solution that used the factory cable for 3rd gen rears with disc on the 4th gen rear with 4th gen disc setup?
I recall there were two versions of the factory design. Was it the first or second? What was the difference? Lastly, what are the part numbers?
Did those old post fall off the board?
Old Jul 22, 2003 | 01:16 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Can you post a pic of your calipers? I recently bought a set of brakes from a '94 IIRC and they are the same calipers as the ones on my '89 PBR rearend and would use the same cable. The only difference is the big round rubber snubber thingy attached to the bracket, you should know what I mean.
I don't have teh part number handy but I asked for a cable for a '89-92 car with the PERFORMANCE brake package, this should get the right ones as long as they're not the LS1 style brakes.
Ed
Old Jul 22, 2003 | 11:09 AM
wm_sorg's Avatar
Hi Ed,
The rear is from an 01 T/A so I am assuming they are LS1 style brakes. I will see if I can post a pic this evening.
BILL
Old Jul 22, 2003 | 08:46 PM
ebmiller88's Avatar
Yep, LS1 style I think. Here's a link to what other's have done to make it work.
https://www.thirdgen.org/techbb2/sho...+cable+bracket
The '89-92 cables won't work for you UNLESS your calipers and e-brake bracket look like this, then you're fine:
Attached Thumbnails Emergency brake cable solution for 4th gen rear swap-lca-reloc-bracket.jpg
Old Jul 22, 2003 | 08:50 PM
_max_'s Avatar
those be lt1 style EB
Old Jul 31, 2003 | 01:32 PM
wm_sorg's Avatar
Sorry for the delay. I will post pictures this evening. I need to get this figured out.
Old Jul 31, 2003 | 09:13 PM
wm_sorg's Avatar
Here is the picture of my rear caliper.
Attached Thumbnails Emergency brake cable solution for 4th gen rear swap-rbrakes.jpg
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
hectre13
Dec 11, 2023 08:14 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
