Socket size to remove lower control arm rear bolt
I'm doing the rear disk brakes on my 87 IROC. When I went to remove the rear lower control arm bolt to lower the control arm to get access to the lower caliper bolt, I didn't have correct size socket. 11/16 is too small and 3/4 is too big. Is this bolt really 23/32 in size. I have numerous socket sets and this size is not included. I also can't find this socket anywhere. Would a 18mm socket work? If so, I will have to purchase this since this size in also not included in a standard socket set. These rear brakes are a PIA.
Re: Socket size to remove lower control arm rear bolt
Yup... for the most part, engine is SAE, chassis is metric.
Although, the old Saginaw brakes themselves, being OLD, are SAE. 5/16" Allen and such.
With the cast iron rear discs the control arm on one side is in the way. 89-up PBR discs are a walk in the park comparatively, with their 'quick change' pad design.
