Front Control Arm Bolt Size?
Old Jan 14, 2011 | 10:50 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
If the size is somewhere on this site, my search-fu is weak. I'm swapping out control arms for ones with new bushings/balljoints/etc and I'd like to replace the bolts as well. Can't find the size anywhere and no second car to use after I pop the factory ones off. If I wasn't doing this job today/tomorrow I would've just ordered a set from Spohn or something. Any help would be appreciated!
Old Jan 14, 2011 | 10:59 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Front Control Arm Bolt Size?
they are 12mm diameter grade 10.9, you can measure the length and find something close. I can get you a better idea later if nobody else chimes in.
Old Jan 14, 2011 | 11:51 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
From GM.
Nut 11516073
Bolt 11502603
Bolt 11500952
Bolt, Hex (M12 x 1.75 x 95) and the other is Bolt, Hex (M12 x 1.75 x 115).
The above from my 82-85 Parts & Illustration Cat., which shows the two bolts as different sizes--and the ones I put on my 85 IROC are different. Spohn's site, for what it's worth, shows two sizes as well. My 82-91 Parts & Illustration Cat., however, shows only one part number, 11502603 (M12 x 1.75 x 95).
JamesC
Old Jan 14, 2011 | 01:50 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Suh-weet. Thanks! I'll hit up Tacoma Screw or something and pick up both sizes to be safe. Looking at the bushings I think I'll need both. One of the bushings was significantly longer than the other.
Old Jan 14, 2011 | 02:22 PM
JamesC's Avatar
Since those bolts will eventually seize to the metal of the bushings (don't ask me how I know or how long it took to remove them), I'd slathered the unthreaded shank with anti-seize to be on the safe side.
JamesC
Old Jan 14, 2011 | 03:51 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Are full threaded bolts okay or should I go for the OE style shanked? I would imagine fully threaded bolts would wear prematurely?
Old Jan 14, 2011 | 05:03 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
i would pass on the all threaded bolts, but be sure the bolts you buy are of the proper hardness, grade 10.9 at least.
Old Jan 14, 2011 | 05:55 PM
JamesC's Avatar
JamesC
Old Jan 15, 2011 | 12:47 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Wait, so grade 5 isn't good enough? Yeah, I absolutely thrash my car so I'm not going to be trusting the main front suspension piece to undersized hardware. Thanks.
I succumb to getting the exact right bolt and ordered the hardware set from Spohn. As much as I'd rather avoid it I postponed the install for a bit. But I went ahead and also ordered replacement rod ends for the rear control arms/panhard so I'll put those on as well. For some reason the driver side LCA had a ton more slop than the passenger.
Old Jan 15, 2011 | 09:37 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
just looking out for ya
1992rs/ss
Jan 31, 2025 05:10 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
knight72
Aug 10, 2015 09:32 PM
