Front Brake Upgrade?...
Old Apr 29, 2020 | 07:39 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Is there a front brake upgrade for thirdgens that fits under 15-inch wheels? 'Would be nice to have something better than the stock 10-1/2" brakes, but I have no intention of putting bigger wheels on this particular car...
Old Apr 29, 2020 | 08:19 PM
2knight's Avatar
Car: 1982 Trans Am
Engine: 5.7 ls1
Transmission: 4l60e
Re: Front Brake Upgrade?...
Im looking for the same info. I have 15" stock turbocast rims and im not changing them. But the brakes suck and fade at high speeds.
Old Apr 29, 2020 | 09:22 PM
Drew's Avatar
The 1LE front brakes should fit under 15" wheels, but they're so obsolete they're hard to find any support parts for them any more.
Old Apr 30, 2020 | 09:23 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The C4 standard 12" rotors and calipers ('90 is a good year to use) fit under the later year RS 15" wheels. Those combined with some decent pads work well. Can use the stock disk/hub cut down for the new disc hub. Longer wheel studs are recommended.
Caliper bracket is easy to come by.
Need to cut the ears off the steering knuckle and drill/tap some holes. Be sure to get the Corvette rear disc's (NOT front) for the swap. There is a write up here somewhere for this swap.
And am sure there is a vendor offering a bolt on swap (machine work already done).
RBob.
Old Apr 30, 2020 | 01:34 PM
2knight's Avatar
Car: 1982 Trans Am
Engine: 5.7 ls1
Transmission: 4l60e
Not trying to hijact this thread, but someone has had to have tried the 1le brake upgrade with turbocast 15" rims. I don't want to hack up my spindle just to find out that they won't fit Also are the corvette rotors the same diameter as the 1le rotors?
ss85tadude
Apr 10, 2004 09:09 PM
i8a4re
Feb 17, 2004 02:20 AM
Sciguyjim
Jul 5, 2002 12:18 PM
Buck268
May 20, 2002 02:45 PM
