LS Brake backing plate torque
Old May 6, 2022 | 12:40 PM
thatsupnow's Avatar
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
Hey guys just curious what y'all are running for torque on the brake backing plates for the LS rear brakes?? Mine are on a MWC 9" and I set torque to 40 ft lbs. Is that enough or should I bring it up to say 50-60 ft lbs?? I couldn't really find a definitive answer. Thanks guys
Old May 6, 2022 | 04:14 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: LS Brake backing plate torque
3/8" T-bolt at axle flange? Clean threads, apply Loctite, and use standard torque (35 lb-ft). Loctite doesn't do jack squat unless it's applied like a sloppy mess.
Midwest doesn't actually give you T-bolts, they just grind the side down of a hex head bolt.
Old May 6, 2022 | 09:06 PM
thatsupnow's Avatar
Hahaha they sure do! Okay perfect thanks again!
Dkelz313
Brakes
Oct 31, 2015 10:19 AM
8t2 z-chev
Apr 28, 2013 11:45 AM
acholoik
Apr 11, 2007 10:20 PM
llvll4l2c91350
Feb 3, 2004 08:59 AM
