BRAKE PROBLEM
Old Sep 20, 2022 | 08:16 AM
kaos420's Avatar
Car: 88 gta
Engine: 5.8
Axle/Gears: 3.73 POSI
BRAKE PROBLEM
So i have a 85 camaro im having a hell of a time figure out this brake problem.So the problem is after bleeding the system i start the car an get pretty much no pedal like theres air in the system .i replace the booster an still no pedal i have pulled the proportion valve a part an cleaned it samething .i then borrowed a vacuum bleeder from a guy at work an used that.hooked it up to the rear calipers an pulled all air out got to the front an its pulling fluid but its like its air bound an doesnt want to get all the air out its pulling so much air the lil bit a fluid its pulling is milky it will empty the res but its not getting the air out.but if you bleed the brakes by just pumping them the old way fluid pours out but when you start the car an apply the brakes it pretty much goes to the floor.there is new brake line steel braided hoses new calipers new master..im truly at a loss with this problem!!!!!!!!!!!!!!
Old Sep 20, 2022 | 07:41 PM
Re: BRAKE PROBLEM
How did it go when you "bench bled" the master cyl?
Old Sep 20, 2022 | 09:16 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Re: BRAKE PROBLEM
Calipers upside down? Everybody does it once.
At least that's what I tell myself.
Old Sep 23, 2022 | 09:47 AM
kaos420's Avatar
Car: 88 gta
Engine: 5.8
Re: BRAKE PROBLEM
NO wish it was that simple
Old Sep 25, 2022 | 09:01 AM
Beeman's Avatar
Re: BRAKE PROBLEM
Time to diagnose. You can start at either end but I would buy 2 plugs for the MC and remove the lines and plug the MC. If you don't get a rock hard pedal with the MC plugged you found where the problem is. If the pedal is good with the plugs remove 1 plug and put that line in and see what you get. Basically isolate each section.
Old Sep 30, 2022 | 07:37 AM
kaos420's Avatar
Car: 88 gta
Engine: 5.8
Re: BRAKE PROBLEM
Didnt think of that thanks ill try that tonight
c10chas
Brakes
Aug 10, 2011 10:35 AM
M1tch
Brakes
May 20, 2008 09:57 PM
Jaime-TA-84
Brakes
Sep 8, 2006 02:19 PM
k&n
Brakes
Oct 22, 2004 02:11 PM
88Roc350TPI
Jun 21, 2001 07:59 AM
