What's the brake issue?
Old Sep 30, 2022 | 03:23 PM
rsc350's Avatar
Car: 92 Camaro RS
Axle/Gears: 3.73 Truetrac
Stock brakes. I have bled the brakes with no issues (lines not clogged?), and replaced the master cylinder. The brakes are horrible, they do not pull one way or the other. It seems unlikely that both calipers are bad, or are they? What am I missing?
Old Oct 1, 2022 | 02:47 PM
tomsaddy's Avatar
Car: 1987 GTA
Engine: TT LC9
Axle/Gears: 3.50
Re: What's the brake issue?
How much pedal travel is there? Does it go to the floor? Is the booster in good shape? Good vacuum?
Old Oct 1, 2022 | 03:01 PM
rsc350's Avatar
Car: 92 Camaro RS
There is quite a but of travel, but I do not bottom it out, i guess it would but I typically down shift to keep control so I don't have to. There is plenty of vacuum. I thinking maybe the proportioning valve? Do those typically go bad and effect both sides when they do?
Old Oct 1, 2022 | 03:08 PM
tomsaddy's Avatar
Car: 1987 GTA
Engine: TT LC9
Axle/Gears: 3.50
Sounds like there’s still air in there. You bench bled the master before installing?
Old Oct 1, 2022 | 04:22 PM
rsc350's Avatar
Car: 92 Camaro RS
I did. And they were exactly unchanged.
TransAmGTA88
Brakes
Mar 1, 2020 11:50 AM
FireDemonSiC
Brakes
173
Dec 24, 2012 01:16 AM
Timinsk
Brakes
Jan 8, 2010 10:36 PM
spearson
Brakes
Mar 2, 2006 01:39 PM
86 sports coupe
Oct 14, 2002 05:18 PM
