Drum to disc conversion kit
Old May 18, 2023 | 09:28 AM
jcammin's Avatar
83 berlinetta, wanting to convert my rear drum brakes to disc brakes because I am about to replace brakes anyway. Someone considered LS1 brakes if I am going to add power later on, which I am. Can anyone point me in the direction for a conversion kit?
Old May 18, 2023 | 11:41 AM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
Re: Drum to disc conversion kit
the two companies I see mentioned the most regarding thirdgen brake swaps are:
Flynbye Performance
Big Brake Upgrade
I purchased a Gen 5 Camaro SS brake upgrade package for my Trans Am from Big Brake Upgrade. Can't say enough good things about Scott and his products / customer service.
I've never purchased anything from Flynbye.
Old May 18, 2023 | 07:31 PM
BBCSwap's Avatar
Engine: SBC Dart 400 Holley 750 Carb
Axle/Gears: 28 spline 323 gears
I did the LS brake swap. I would look at the LE swap for the rears. Might save some cash.
Old May 19, 2023 | 03:08 AM
SlowAndSteady's Avatar
Car: 86 Camaro IROC
Transmission: stock autom.
Axle/Gears: stock
Dont forget to change the Brake Proportioning valve or mod it
I failed the german technical inspection test . they test your brakes on a Testbench ......it failed really hard ...almost no breaking on rear axle ....because Drums need far less pressure in comparsion to disks
new valve was way to expensive (an very rare also) to me an so i simply changed the spring in it
( measured it lenght, wideness and springforce . contacted a Manufacturer in sweden and let dem make me 3 sets of custom springs in different forces . one of them was perfecly right to get correct readings on the Testbench )
3 springs plus shipping had cost me 10 $
Old Jul 20, 2023 | 12:51 AM
ownor's Avatar
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
you got PM 🙂
Formula4Speed
Jul 23, 2004 04:40 PM
89305RS
Feb 18, 2004 10:41 AM
westman
Oct 27, 2003 09:59 PM
demonchild
Sep 6, 2002 04:52 AM
unknown_host
Apr 25, 2001 10:57 AM
