9 Bolt PBR Calipers
Old Aug 6, 2023 | 09:34 AM
Mike.The.Squid's Avatar
Car: 1989 IROC-Z
9 Bolt PBR Calipers
Does anyone have part numbers for the proper calipers for the 9 Bolt rear with the aluminum PBR calipers / Pads / Rotors. I want to make sure I am ordering the right stuff. Thanks
Old Aug 6, 2023 | 09:51 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: 9 Bolt PBR Calipers
You will most likely get a new china part, if you can, rebuild your factory calipers. (if they really need it) Mine have 250k on them and are just fine.
Old Aug 6, 2023 | 09:09 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Just a heads-up. The 9- and 10-bolt PBR braking systems are interchangeable. To that end, you may find some of the info/part numbers in the following link beneficial: https://www.thirdgen.org/forums/faq-...iscs-89-a.html
JamesC
Old Aug 7, 2023 | 09:22 AM
Right: calipers, pads, brackets, etc. interchange. Backing plates do not. But if your 89 already has those, you won't have to worry about them.
Old Jul 31, 2024 | 11:59 AM
Car: 1989 IROC-Z
Thanks for the info, this is helpful.
My car has been sitting for almost 20 years, I figure they need replacing, but I will see if I can find parts to rebuild.
dagwood
Brakes
Dec 17, 2020 06:08 PM
91 camaro rs
Brakes
Nov 29, 2008 05:02 PM
abray1
Brakes
Mar 31, 2008 02:35 PM
//<86TA>\\
Brakes
Apr 22, 2007 01:27 PM
foney_email
Sep 10, 2002 04:27 PM
