Brake caliper
Old Aug 18, 2023 | 02:11 PM
Zbob90's Avatar
Car: 83 TA
Engine: 350 V8 1996 GMC
Transmission: 1982 TA 3.16 - 1
Brake caliper
I'm trying to swap calipers on my car and having trouble getting the new ones installed. There is a tab on the pad that is supposed to line up with the slot circled in the picture but it's rotated on an angle a bit. I can get the tab in and the circlip attached but as soon as I go to try and set the caliper itself pad pops out.
Is there a way to rotate the piston with out dismantling it and damaging it, or should i just return the caliper? Compared to the old one it doesn't seem to be put together correctly.
Its the right rear btw
Old Aug 18, 2023 | 02:51 PM
Airwolfe's Avatar
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
Re: Brake caliper
It's not a brake caliper from a 3rd gen Camaro or Firebird.
Sorry for my mistake. I forgot about the 88 down Delco-Moraine rear brake calipers. Actually trying to forget about them because they absolutely suck.
Old Aug 18, 2023 | 02:56 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Brake caliper
Those pistons rotate in the bore with either the specific tool for that or any other method you can figure out.
Those 82-88 rear calipers are such a pain to deal with.
Old Aug 18, 2023 | 04:57 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: Brake caliper
^ I've been able to turn them with a large enough channel locks. Be careful not to snag the rubber
86Trans Am 921
Brakes
May 7, 2006 09:17 PM
1meanGTA
Brakes
Jul 4, 2005 10:02 PM
1meanGTA
Brakes
Jul 3, 2005 09:45 PM
phess11
Brakes
Apr 11, 2005 06:39 PM
Red Devil
Feb 25, 2001 11:40 AM
