Servicing Rear Driver Brake Caliper
Old Feb 5, 2024 | 08:03 AM
rymanrph's Avatar
Car: '88 IROC
I'm in the middle of a full brake overhaul (new master, hard lines, flex lines, calipers, pads, rotors, parking brake cables) on my '88 and I'm having some issues with the disc brakes on my 9 bolt. The driver side caliper (stock replacement) is incredibly tight to the point where I had to use a rubber mallet to get the caliper and pads to go over the disc. In neutral, the wheel doesn't spin. It's possible that my parking brake cable is too tight (not sure yet), but I'm in the process of bleeding the system as well. In case I need to take my caliper back off to make adjustments, how am I supposed to do that without disconnecting the hard line and re-bleeding? The passenger side has a flex line between the hard line and the caliper, but the driver side has a hard line that goes directly from the T on the axle all the way to the caliper. Even for a routine pad replacement, how would you do that without a flex line?
Old Feb 5, 2024 | 08:29 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: Servicing Rear Driver Brake Caliper
That one caliper might be a defect. Even if it is new.
johnw999
Brakes
Jan 18, 2013 11:27 PM
screamnbanshee
Brakes
Aug 13, 2010 03:14 PM
Tremo
Brakes
Feb 1, 2007 06:35 AM
miacamaro305
Mar 10, 2005 08:29 PM
hurricanerugger
Dec 16, 2002 06:54 PM
