Braided brake line for disc rearend???
Old Aug 13, 2010 | 03:09 AM
screamnbanshee's Avatar
heres the low down.. i got an 86 disc brake rear end.the brake lines on one side are full hard line from "T" to caliper, and the other side has a section of soft line between the "T" and caliper.
does anybody make a stainless braided brake line for this location?? i can only find fronts and the rear line from chassis to rearend in braided lines.
since both the calipers are mounted to the rearend the exact same on both sides, why have one side hard and one side soft? can i just make the side with the softline into a full hardline like the other side or will that cause a problem??
Thankyou to all who have any input on this
Old Aug 13, 2010 | 02:15 PM
87350IROC's Avatar
Car: 87' IROC
Re: Braided brake line for disc rearend???
Goodridge sells a full kit for our cars that includes the piece you are looking for.
Old Aug 13, 2010 | 02:29 PM
since both the calipers are mounted to the rearend the exact same on both sides, can i just make the side with the softline into a full hardline like the other side or will that cause a problem??
Old Aug 13, 2010 | 02:36 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
An 86 should have opposing calipers. 89+ have the calipers to the rear.
JamesC
Old Aug 13, 2010 | 02:38 PM
one caliper is on the front and one toward the rear
Old Aug 13, 2010 | 02:42 PM
do you have the goodridge part number? i cant find the correct line set. i need two front lines, one rear chassis to rearend, and one is on one side of the rearend to caliper(4 total). the sets they sell have 5 lines?? do i use that set and just end up with an extra??
Old Aug 13, 2010 | 02:51 PM
87350IROC's Avatar
Car: 87' IROC
Part number is goodridge 12252.
I don't see a problem with making it a hardline except it will make pad and rotor changes a pain. I wish they were soft lines on both sides.
Old Aug 13, 2010 | 02:59 PM
thank you. do you know if the banjo fitting end for the front caliper are able to be put on the rear calipers?
Old Aug 13, 2010 | 03:14 PM
87350IROC's Avatar
Car: 87' IROC
I have no idea. If they are the same size, I would imagine they would work fine.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Carburetors
Aug 21, 2015 02:42 PM
Nj1987
Aug 19, 2015 08:26 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
