Rear brake caliper bottom bolt
Old Jun 28, 2024 | 07:47 PM
Dinero's Avatar
Car: 1988 GTA
Engine: 5.7
So am trying to get the caliper out of the way to replace the pads. I removed the top bolt and am able to rotate the caliper out a bit only. when I try to rotate it down, the e-brake part hit the differential so it will not move down anymore. Plus I cannot see how the bottom bolt can be removed with all the e-brake stuff in the way. So I did do a search but did not find any hits. Any help appreciated. Thanks
Old Jun 30, 2024 | 07:55 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Rear brake caliper bottom bolt
If you have 82-88 rear disc, remove 1 side of the control arm and swing it down out of the way to remove the lower bolt.
it's a crappy design from the 2nd gen cars.
design.if you can, upgrade to 89-97 rear disc and be happier
Eric-86sc
Jun 22, 2015 10:30 PM
tonys91rs
Brakes
Oct 14, 2013 11:55 AM
91 camaro rs
Brakes
Mar 15, 2009 07:17 AM
bbsr72
Brakes
Jul 10, 2008 02:20 PM
bigals87z28
Brakes
Apr 27, 2008 04:27 PM
