Hod difficult is to replace from brake lines?
Old Mar 29, 2026 | 08:31 AM
drabina's Avatar
Car: 92 Camaro RS
Engine: V6 3.1
Transmission: 5 speed
Looking at a schematic, the front brake line from MC to passenger side caliper goes along a cross-member on the engine side. Is the replacement possible (using a pre-bent line) without removing any components or raising the engine? I have the 1992 V6 Camaro if that matters.
Old Mar 29, 2026 | 04:46 PM
Firechicken82's Avatar
Car: 82 TA
Transmission: Magnum f
Axle/Gears: Ford 9 w 4.11
Re: Hod difficult is to replace from brake lines?
There are little bolted in tabs that hold the brake line. Depending on your x member to oil pan clearance, you may be able to swap it w the engine in place. My car cannot, i was able to get the bolt backed out but it hit my oil pan before it was fully out so it wasn't happening w the engine in.
CRAZYCHUCK13
Aug 7, 2025 11:06 AM
WILL85IROC
Brakes
Oct 24, 2013 07:14 AM
Ben92
Brakes
Nov 18, 2007 11:35 PM
steve87iroc
Brakes
Mar 15, 2005 05:14 PM
83 Crossfire TA
Oct 16, 2002 05:52 AM
