replacing front right brake line...
Old Sep 28, 2013 | 06:51 PM
WILL85IROC's Avatar
Car: 85 IROC-Z Z-28, BLUE & SILVER
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
my front left brake line was clogged and I couldn't bleed the brakes after replacing the calipers so I bought a front brake line kit from jegs. it came with 4 lines prebent for 84-85 Camaros, I changed the drivers sides with no problem but the passenger side it longer and runs under the engine across the k member, my question is how do I change it? do I have to lift the engine or drop kmember?? I don't see any other way to snake it thru... thanks...
Old Sep 28, 2013 | 08:01 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Re: replacing front right brake line...
its the rubber lines to the calipers that collapse not the hard lines.
Old Sep 29, 2013 | 08:30 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Old Sep 29, 2013 | 10:07 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
The line is bolted to the k-member below where the engine sits. Don't see how it could be properly replaced without raising the motor. I've replaced them before but the motor was already out.
Old Sep 29, 2013 | 12:19 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
I would leave it be and just replace the rubber line. Thats usually the one that fails. You can keep the hard lines for spares down the road.
Old Sep 29, 2013 | 12:55 PM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
ok thanks... wasn't sure if I could change it without raising the engine....
Old Sep 30, 2013 | 08:16 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
It'd be tough.
I agree with everyone else...hard lines rarely fail unless they rust away.
But unless you have a concourse car that you are trying to win awards with, i would just make new lines from a roll or sections at the parts store. I just recently bent up some new lines for mine, and completely avoided the k-member under the car. I was trying to make it so that if I ever had to drop the K or the motor again, I wouldnt have to disconnect the front brakes. One less thing... And as far as I can tell, its gonna work well.
There is no real iron clad way to run the lines. As long as you dont put them in harms way, and you dont create any crazy high points that can trap air, you can run them however you want. Even use a union if you have to as long as its a brake line union.
Good luck getting her straightened out!
J.
Old Oct 23, 2013 | 03:34 PM
dmwracing42's Avatar
Car: 1984 Trans Am
Engine: 355
Axle/Gears: 10 Bolt, Torsen Diff, 3.73's
Not to hijack the thread, but how in the hell do I get the soft lines off without stripping the nuts off. My line wrench has been unsuccessful
Old Oct 23, 2013 | 05:09 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Sometimes they dont come apart. You can try good penetrating oil, you can try some heat be be very very careful doing so, dont want to build up pressure n the system and have something burst
Old Oct 23, 2013 | 05:36 PM
LsxMatt's Avatar
Car: 86 Sport Coupe
Engine: 5.3 LM7
Axle/Gears: 4th gen 3.42 posi
A large set of vise grips always work for me .Just go slow to make sure the line isn't rusted to the nut, otherwise you'll twist the line while turning it.
Old Oct 23, 2013 | 06:36 PM
Car: 1992 Camaro RS
Just one of those good reasons to keep some hard lines for a spare. It can be a booger bear sometimes to get those things apart.
Old Oct 23, 2013 | 09:04 PM
Car: 1984 Trans Am
Engine: 355
The engine's out...I may very well take this as an opportunity to change the hard lines too lol.
Old Oct 24, 2013 | 07:14 AM
Edwardgp's Avatar
Engine: 454-350
That would probably be the way to go.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
TheExaminer
Aug 25, 2015 07:34 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
