[MO] wtt 87 trans am gta for built camaro
Car: 1992 Camaro
Engine: HSR 355, afr 195s, xfi280, Holley e
Transmission: t-5
Axle/Gears: Braced 10 bolt Auburn and 3.73s
have a 1987 Trans Am GTA with a clean title.car has 163,xxx miles and less then 10k on motor.or sell for 6500
wanting a built 5 speed t top car. looking for 400 to 500 hp like the trans am. im just a camaro guy.
1. 350 .40 over. forged internals
2.new valves, springs, guides, and hydrolic matching lifters 10 miles
3.brand new TrickFlow Camshaft, Hydraulic Flat Tappet, Advertised Duration 308/316, Lift .495/.510 10 miles
4.Proform Timing Gear Drive Set, Dual idler 8 degree max advanve/retard at camshaft.10 miles
5.holly street dominater intake. dual plane idle-6000 power band
6.edelbrook 750cfm carb vaccum secondaires. 10 miles
7.new msd plug wires new cap rotor and plugs. and new battery
8.hedman shortie headers.
9.flowmaster 80 series exhaust no cat.
10. 12 bolt rear with 4.11 posi gears
11. front and rear compotition enginering drag shocks (rears not installed)
12.new traction bars. sway bars. frame connectors and frame ties. transmission crossmember. lower control arms. panhard bars, drag springs, and tourqe arm.
13.fiberglass 4in cowl hood painted to match car.
14.borgwarner 5 speed transmission
The_Phoenix
Feb 4, 2016 07:10 AM
