Canadian Region Take off to the Great White North.
Anyone from the Interior of BC?
Old 07-07-2005, 05:57 PM
  #151
FastElectrics's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
So whats happening with any kind of meet up? Glen, Apeiron, Brisk, Crimson 383 cid (though I'd imagine your installing the blower). It's been so quiet here ...
Old 07-07-2005, 07:40 PM
  #152
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I'm still trying to get a weekend free so I can turn a bare block and a pile of parts into an engine.
Old 07-07-2005, 09:56 PM
  #153
Car: 89 Camaro RS
Engine: 305 TBI
wow... ok.. quick fix.. cut a hole through the floor, and go flinstone style..
Old 07-07-2005, 10:22 PM
  #154
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
In the time it would take to cut the floor out I could just build the engine.
It's not so bad, really. The longer I wait, the more parts I end up buying.
Old 07-07-2005, 11:26 PM
  #155
Car: 89 Camaro RS
Engine: 305 TBI
lol... isn't that the truth... By then it'll be winter... and then you can put it off some more. Then spring will come, and they you will start thinking.. "I should build the engine".. then summer hits.. and ah crap.. the cycle starts again..
Old 07-07-2005, 11:34 PM
  #156
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No, it'll be done and back in the car just in time for snow. Then I'll strip the body to bare metal over winter but in spring there won't be time to shoot it until the following fall.
Old 07-19-2005, 12:36 AM
  #157
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Ok, I finally got some work done on it over the weekend. The block is parallel decked, honed, tapped, plugged, cleaned and painted, the crank is ground and the heads are milled and reassembled.
Old 07-24-2005, 02:34 AM
  #158
CC74Z28's Avatar
Car: 74 Z28, 85 Firebird , 87 GMC 3/4
Engine: 350 in Z28 2.8L six in the Firebird. Truck Gas Pig
Williams Lake and I can't believe how big this board is!!!
Old 07-24-2005, 05:24 PM
  #159
88maro85chicken's Avatar
Car: 88 z 85 Firebird SE
Engine: 350 305
Transmission: 350 t 700r4
hey cc lac la hache here
Old 08-08-2005, 03:46 AM
  #160
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Just when I thought I might actually get the short block finished today, I find out my rods are hitting the cam. :P
Old 09-19-2005, 02:22 AM
  #161
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Had another weekend to work on the car. I had my pistons balanced onto a new set of Eagle H beam rods to fix my cam clearance problems on Friday. A fair bit of weight had to be added back to the crank since the H beams are considerably heavier in the big ends than the old I beams. Fortunately all the weight was put back where it had been drilled out previously, so no expensive mallory metal or anything was needed. I trial-fit everything and found I'm going to need some more grinding on the block to clear the heavier rods, but at least I have a ton of clearance between the rods and cam.
Old 01-10-2006, 11:09 PM
  #162
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I guess I don't count, since I moved, but I thought I recognized crimson 383's car.... More specifically, the T-bird in the background (err, T-birdS eh?)
Ever finish your car Cody? Collin told me a while ago Ryan had his T-bird dynoed that showed something rediculous (high), dumbass couldn't even remember the #'s.... You know anything about that?
I'm 'restoring' an '82 TA now, i'll be starting a thread here about what i've done to the rear suspension in the canadian region forum here...
Old 03-19-2006, 02:33 PM
  #163
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
booya.. anyone out here still alive?? I know I'm starting to unthaw, spring is just around the corner.
Old 03-24-2006, 02:48 AM
  #164
Normaro's Avatar
Penticton here..... I've got a 91 RS camaro 305 th700. Off the road right now, Tranny died Any of you guys know anybody scraping a 3rd gen. with manual tranny? I want to change it out and put a 5-speed in. I figure it is better to but a scrap car for all the parts, Clutch pedals, master cylinder...... Once my RS in back up and running it would be great to get together.
Old 03-27-2006, 01:02 AM
  #165
ikillu's Avatar
Car: 91 Z28
Engine: 383 stroker HSR
Axle/Gears: 3:73 posi
From Trail BC here. Gonna have the car up and running in about 6 weeks.
Old 03-27-2006, 01:11 AM
  #166
Normaro's Avatar
Found a good site for 3rd Generation part www.driverfx.ca and the best part is its Canadian.. Be careful some parts are marked way up. ie Console megashifter for Camaro at Lordco 213.00, on this site 370.38 wow big difference. But some parts are great... I found a coversion kit so I can put a th350 in my 91 RS.
Old 03-28-2006, 08:09 PM
  #167
Brisk's Avatar
ikillu .. nice to see someone more local to me, I'm in Castlegar
Old 03-28-2006, 10:34 PM
  #168
ikillu's Avatar
Car: 91 Z28
Castlegar eh? Right on. If you need any parts let me know.
Old 03-29-2006, 12:05 AM
  #169
Brisk's Avatar
ikillu I sent you a PM.. check your messages.. what parts you got?
Old 03-29-2006, 09:36 AM
  #170
Sonix's Avatar
Car: 1982 Trans-Am
driverfx is basically the special order site for canadian tire. technically it's ekeystone.com but unless you have a username and password you can't check prices on that.
but if you get c-tire to order from driverfx.ca for you, then you usually don't pay any of the shipping, you just pick it up from c-tire.
Old 04-24-2006, 07:21 PM
  #171
Car: 89 Camaro RS
Engine: 305 TBI
I'm still around. Been away from this site for a fair while.
Normaro: do you have your car back on the road now.
Old 04-25-2006, 08:04 PM
  #172
88strokedmaro's Avatar
Just bought a great car through VFbody on the weekend... 91 350 hardtop...
Old 04-25-2006, 08:54 PM
  #173
Brisk's Avatar
right on, throw up some pics!
I still have an '88 IROC for sale if anyone is interested.... .. .. .. ... .. . .. .. ..
Old 04-25-2006, 11:31 PM
  #174
Crimson 383 cid's Avatar
Car: 1987 Camaro
Engine: 383 C.I.D.
Transmission: 700 R4
Hey guys, I just got the internet back. My engine ate my tranny so the car is off the road for a bit. I also dont have any pictures on my new computer so if anyone by chance has any saved I would like them. they are on my old roomates computer and it died unfortunatly. but whatever.
Man, the weather here in Vernon latly makes me miss my car sooo much.
Hey brisk im thinkin' about getting another third gen. can you send me an e-mail with pics of your car and info along with price please??
codyreay@hotmail.com
Old 04-26-2006, 07:14 AM
  #175
Brisk's Avatar
I think I have a couple pics of your car around here somewhere.. I'll see if I can dig them up and post'em here or email them to you.
Old 05-27-2006, 02:22 AM
  #176
GFTransAmGTA's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L/350
Transmission: auto
I am new here and i am form Grand Forks BC.
Old 05-27-2006, 11:53 AM
  #177
Brisk's Avatar
Welcome to the boards!
Old 06-20-2006, 11:30 PM
  #178
CanadianRocky's Avatar
Cranbrook is home
I have wanted to run a car at the Salt Flats since I was in my mid teens.
Now I have the time and money to do it.
The plan is to get the car either this year or next, build it over the winter of '07 and run on the salt in '08.
Phase one is to get into the 130 mph club
Phase two is to get into the 150 mph club
Phase three is to go over 200 mph.
It starts now.
Old 08-03-2006, 03:47 PM
  #179
Brisk's Avatar
CanadianRocky - so hows your quest going along so far?
:wave: fellow Canadians.. its been pretty quiet in here!
Old 08-03-2006, 06:58 PM
  #180
ikillu's Avatar
Car: 91 Z28
hey there
Still alive. Car build going too slowly but that's ok. Brisk I got a taillight for you if you are still looking. Make me an offer.
Old 08-04-2006, 12:07 PM
  #181
Brisk's Avatar
ikillu, u have a pm.
Old 08-06-2006, 09:35 AM
  #182
Car: 89 Camaro RS
Engine: 305 TBI
I'm still alive too. The Camaro is finally off 'daily driver' status. so perhaps I might be able to get somethings done to it now.
Old 08-11-2006, 12:02 AM
  #183
Camaro427SS's Avatar
Im From Kelowna, If you ever see the car in my sig driving around with a kid with semi legenthy black hair, and a guy a bit older driving around in it.thats us :P PS the 327 decals arent whats sitting in it...:P
Old 08-23-2006, 01:58 AM
  #184
jester_043's Avatar
i am from merritt b.c
Old 08-29-2006, 05:03 PM
  #185
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Jester, I live in Kamloops. My GTA is parked and collecting dust at this time but I am going to try and get it running this winter (when I have more time).
Also Chris (Aperion) lives in Salmon Arm. Maybe the three of us can meet at my place, have a barbeque and talk cars one weekend.
Old 08-31-2006, 08:43 PM
  #186
jester_043's Avatar
olny one problem i need a car haha, and i olny have my learners right now, i have been looking around for a car for under 3 grand
Old 09-01-2006, 10:13 PM
  #187
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Would anyone be interested in a 3" mandrel-bent, TIG-welded stainless steel exhaust with a bullet muffler?
Old 09-03-2006, 12:34 AM
  #188
Car: 89 Camaro RS
Engine: 305 TBI
Hey Glen, what about me! I have not really met any thirdgen owners in BC yet.
Apeiron, your not to far either. My car could probably use a drive before the end of the season.
Old 09-06-2006, 06:54 PM
  #189
Car: Death Mobile
Engine: 666 c.i.
Anytime Fastelectrics (aka Tony IRC). You may be able to make arrangements with Jester since he's "on the route up". Chris (Aperion) is in Kamloops most every other weekend, so I'll just entice him with beer & steaks.
Old 09-06-2006, 07:05 PM
  #190
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Did someone say beer?
Old 09-06-2006, 07:29 PM
  #191
Car: 89 Camaro RS
Engine: 305 TBI
It's possible. We'll have to arrage something sometime. My days off work however are Sunday's and Monday's. not the norm. I'll be going to the coast on the 17th. so currently most weekends are free.
Old 09-06-2006, 11:49 PM
  #192
Brisk's Avatar
mmmmmmmm, beer.
Old 09-09-2006, 06:58 PM
  #193
WhiskeyChick's Avatar
Car: 1987 Trans Am GTA
Engine: 305 V8
Transmission: 5spd
Axle/Gears: 9bolt
Hellos, thought I would post in here, Im currently living in Kelowna, takin autobody at the OC. Oh yea, I drive a 1987 GTA, 5spd 305, and im trying to get it trailered down here (its on the island) and am looking at buying a green 87 GTA that I saw cruising around here for sale....
Old 09-09-2006, 08:25 PM
  #194
Car: 89 Camaro RS
Engine: 305 TBI
Hey right on man, I took the same course also, re-did my camaro. We should hook up sometime,
Old 09-18-2006, 10:11 PM
  #195
Car: Death Mobile
Engine: 666 c.i.
If any of you guys are interested in getting together for a barbeque and beer in Kamloops (before winter sets in), let me know.
I'm not to sure how the weather is going to be this weekend, but let me know if any of you are interested.
Old 09-18-2006, 10:14 PM
  #196
Engine: 305 V8
Transmission: 5spd
Axle/Gears: 9bolt
Hey Id be game but the GTA is still back home until it gets trailered here in November, till then I got no wheels
Old 09-19-2006, 04:08 AM
  #197
Brisk's Avatar
I'm out for this weekend, its my daughter's sixth birthday.. I'd be hung if I was absent for that!
Old 09-22-2006, 07:52 AM
  #198
Car: Death Mobile
Engine: 666 c.i.
Well, there doesn't look like there is much interest and the weather doesn't look that great. Maybe we can try again next spring.
Old 09-23-2006, 07:21 PM
  #199
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Are you going to get a Harley to go with the new name and avatar?
My next few weekends are probably going to be occupied with actually getting around to putting this thing into a car.
Old 09-23-2006, 08:12 PM
  #200
Brisk's Avatar
mmmm...., oooooh..., aaaahh..., now that looks nice!
Quick Reply: Anyone from the Interior of BC?
