1988 Pontiac Trans Am GTA for sale in Quebec's province
Car: 1988 Pontiac Firebird Formula 350
Engine: 5.7L
Transmission: Automatic 4 speeds
Axle/Gears: 2.77
-1988 Pontiac Trans Am GTA
-115 000 miles
-T-Top
-5.0L TPI
-4 speeds automatic transmission
-3.27 limited slip rear
-WS6 performance suspension
-4 wheels disc
-P245/50R16 tires
-Radio controls on the steering wheel
-Power everything
-Every options except leather and the 5.7L
Here's what been done:
-Original transmission was rebuild about 12 000 miles ago
-4 new coil springs
-4 new shocks
-2 new ball joints
-New Link kit
-2 new Kumho ECSTA 711 245-50-16 tires
-New Starter
-New front brakes hoses
-New front brakes pads
-New ACDelco battery
-New ACDelco rotor
-New ACDelco cap
-New ACDelco PCV valve
-New ACDelco air filter
-New ACDelco fuel filter
-New ACDelco spark plugs
-New 8mm Accel SuperStock spark plugs wires
-Replaced the intake's gasket
-2 new wipers
-Always changed engine oil and filter at less than 5000km or 3 months
-Been aligned at GM in 2004
-Cleaned the IAC and throttle body
-Transmission's oil, filter and gasket changed every summer
-Never winter driven
What need to be done to run good:
-Replace the MAF (It will come with the car)
Other non obligatory stuff you might wan't to do:
-Replace rear brakes pads because in the morning, when cold, they make some noise, but after 1 minute of driving, you don't hear them anymore.
-Driver's side T-Top leak a little
-Rear wing paint is bad and cracked (like they all do)
-Missing 2 rear 6x9 speakers (front ones are there but doesn't play that good since they are very old)
-Replace driver door sill because a very small part is broken
-A/C needs to be charged
-Original radio works with cassette and steering wheel buttons, but can't listen to any radio stations
-Side windows tint begin to come off at the top
-Passenger side fog light bulb need to be changed
-The hatch now close like a regular hatch
-Front nose emblem is missing
-Power antenna doesn't go up and down anymore (Stuck in the up position)
For 20 photos, go to my french web site at http://waonfire.monchar.com
The car's located in Quebec's province.
5000$ firm (Canadian)
-115 000 miles
-T-Top
-5.0L TPI
-4 wheels disc
-P245/50R16 tires
-Power everything
-4 new coil springs
-4 new shocks
-2 new ball joints
-New Link kit
-New Starter
-New ACDelco rotor
-New ACDelco cap
-2 new wipers
I'llrocya
02-02-2016 11:43 PM
1992 Trans Am
08-08-2015 08:16 PM
