can anyone build engine in alberta?
Car: 91 formula ws6
Engine: 1 peice roller scat 383 4 BOLT!!
Transmission: 5 speed
hey all, i belive my motor spun a bearing, after 220 000 kms, so im gonna pull it before a rod goes through the block.
its a 5.0, and im looking to save crank and rods. i want to bore it out to 350,put aluminum pistons, and put and lt4 hotcam in. the heads will be stock, other than springs. If crank is ruined ill throw a 400 crank in
does anyone have a source/ can do it themselves. obviosly i need someone who can bore,hone, and do the rest too.also I want someone who has had expeirence setting a high lift roller setup to the right lash and tightness.
anyone? i'll pay cash,beer, and used engine parts
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
A 400 crank isn't a drop-in replacement into a 305 or 350 block either. You'd need to turn the main journals down to fit the block, and then you'd also need either shorter rods or pistons with higher wrist pins to allow for the extra stroke.
Car: 91 formula ws6
short rods?
3i dont know what your talking about the 383,,,,
I live in drumeheller, (dino town)
Engine: 383 Carb
Transmission: 4L60
There are a number of machine shops in Alberta, especially in Calgary, that can do the work, once you figure out what you actually want.
