Canadian Region Take off to the Great White North.
Winter is hard
Old Dec 16, 2024 | 11:48 AM
seanakeough's Avatar
Car: 1985 Trans Am
Engine: 350/290 crate with 650CFM Holley
Axle/Gears: 3.27 Std 7.75 ring gear 9 bolt
Winter is hard
Old Dec 17, 2024 | 08:21 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Re: Winter is hard
Yup. I try to save up my projects for the winter time, cuz the warmer weather is for driving!
Old Dec 17, 2024 | 09:07 AM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
Re: Winter is hard
Ya got green grass there! How hard can it be!?
Where is that?
Old Dec 17, 2024 | 06:59 PM
skinny z's Avatar
Re: Winter is hard
Where is that?
Seeing the small snippet of the front license plate, I'll say Ontario.
Old Dec 17, 2024 | 10:15 PM
BURD's Avatar
Re: Winter is hard
You mean hard on the cars ?
Old Dec 18, 2024 | 06:08 AM
Bow_Tied's Avatar
Car: 1987 IROC-Z
Engine: L98 5.7L
Transmission: MD8 700R4
Axle/Gears: G80 GW6 3.27:1
Re: Winter is hard
Yes it is a tough time.
Old Dec 18, 2024 | 09:39 AM
skinny z's Avatar
Re: Winter is hard
Where is that?
It can be hard on many levels. Even in the climate of southern Ontario, it can get unreasonably cold. So much so, that without a heated garage or shop, you're not going to be doing any wrenching. That was in or around the GTA. (Toronto). Moved a little further north and it's the "snow belt country". I experienced 3 feet of snow laying on the roof of the Trans Am during a one or two day lake effect snow squall event. Not much of anything goes on 3rd gen wise then.
Move further north, such as my locale now in central Alberta and we see -40°. Things grind to a halt. What's more, with the aforementioned unheated shop, should the need arise to move the Camaro (as it did more than once) the old carbed V8 suffers immeasurably due to the cold starts and fuel washing the cylinders. I saw cause and effect in this regard.
Try it without a garage (I'm in transition).
So, yeah, winter is hard.
Old Dec 18, 2024 | 10:05 AM
BURD's Avatar
Re: Winter is hard
Heated garage is the ticket. My rotors don’t even rust, plus I have the garage decked out, sit out there have a beer, you can see your car in the winter, I take the t tops off in the winter. You can get high humidity inside in the winter. Put a cigar hygrometer in your interior , see what the humidity is.
when you want to hang out, just kick the heat up to 70, it’s nice. Plus I do projects out there all the time.
Old Dec 18, 2024 | 12:30 PM
Engine: LT1, L400
Re: Winter is hard
Gotta have a garage, if you have a "hobby car". And having it heated is key, too.
Definitely not if it's outside! Dude...two winters ago, we got 849" of snow. 849"!!! Last year was rather benign at only ~650". We get snow.....but.....
I mean, I used to live in Maine, we had cold there too. My TA/DD at the time was carb'd. Sold that car w/200k miles still ran like new, so IDK about cold temps having a meaningful impact on engine life. Choke adjustment, maybe....but....
I mean, I "get it"....I used to work in a junk yard in New England. It got cold there....COLD. I pulled parts so I'd be out in the yard in the snow, car frame frozen into the ground, pulling parts, fingers froze....that was hard. I "get it".....but....
....but let's go back and have a look at the OP's pic! Green grass! Sunny day! I mean....it looks simply divine for car driving/ownership there! It looks like most of those houses....HAVE garages! Thus, w/the OP's post? I don't "get it".
And if winter is too hard for car-guy stuff, park the car and transition.
Old Dec 18, 2024 | 01:09 PM
skinny z's Avatar
Re: Winter is hard
]I mean, I used to live in Maine, we had cold there too. My TA/DD at the time was carb'd. Sold that car w/200k miles still ran like new, so IDK about cold temps having a meaningful impact on engine life. Choke adjustment, maybe....but....
Out of context Tom.
Let's leave it at that.
Old Dec 18, 2024 | 01:14 PM
Engine: LT1, L400
Re: Winter is hard
If you say so. Context works for me.
Originally Posted by seanakeough
Grass.....sun.....windows down....IDK. Doesn't look too "hard" from the context of where I'm sitting. ​​​​​​​
Old Dec 18, 2024 | 03:29 PM
Car: 1985 Trans Am
Re: Winter is hard
Ya, that was shortly before she went to bed for the winter. My garage isn't heated but I do venture out periodically listen to tunes. glance under the good, and perhaps the odd startup.
Old Dec 18, 2024 | 07:41 PM
Engine: LT1, L400
Re: Winter is hard
Car looks great! I had to put mine away two months ago. Snow was coming, so I filled the tank, cleaned it up, changed the oil....
....and swapped places with the "****-box" for the winter.
Nite-nite. Time to go skiing.
Old Dec 19, 2024 | 07:21 PM
Bow_Tied's Avatar
Car: 1987 IROC-Z
Engine: L98 5.7L
Re: Winter is hard
Two hours west of GTA, so can confirm. I wish my garage was heated, hard to get that up the project priority list. But I guess I can't complain as long as my family is healthy and I am employed.
Old Dec 19, 2024 | 08:04 PM
Engine: LT1, L400
Re: Winter is hard
Make winter easier?
I basically copied this idea in my garage...works awesome. Cost me $50 bux.
Old Dec 20, 2024 | 03:51 PM
BURD's Avatar
Re: Winter is hard
To put heat in the garage Ottis t that expensive, my thru wall is like $750 , then run your gas line, if yo can’t do the hook ups, hire that out.
I just went out to grab some tools, 65° and 24% humidity. Nice. I put race deck flooring in, you can go out in your socks in the winter months. I went a step further, we dive down to Florida and bought sliding screens for the one car side , very nice in summer. Plus if you open the stairs up to attic, you get a good flow to cool off the attic in the summer months
kfsullivan
Nov 10, 2025 11:30 AM
dmccain
Apr 25, 2023 02:16 AM
gt4373
Aug 27, 2022 11:06 PM
crazyL
Dec 16, 2005 11:56 PM
a73camaro
Feb 22, 2002 10:23 PM
