two 10"s, two amps... what should I do?
Old May 4, 2002 | 07:35 PM
mrzud's Avatar
I have 2 10" Polks
My Amps:
Optimus XL-260 High Power Bridgeable Amplifier
(120-2017) Specifications
Output Power:
Stereo...................... 45 Watts x 4 @ 4 Ohms, 20-20 kHz, 0.5 THD
65 Watts x 4 @ 4 Ohms, 20-20 kHz, 10% THD
60 Watts x 4 @ 2 Ohms, 20-20 kHz, 1% THD
Bridged............................. 130 Watts x 2@ 4 Ohms, 1 kHz, 10% THD
Frequency Response............................... 20-20,000 Hz (+/-3 dB)
MTX Blue Thunder PRO75X2 Amplifier
Specifications
RMS Power measured at 12.5 Volts DC:
37.5 watts x 2 into a 4 ohm load with less than 0.05% THD+N
75 watts x 2 into a 2 ohm load with less than 0.1% THD+N
150 watts bridged into a 4 ohm load with less than 0.1% THD+N
Dynamic Power (IHF-202 standard) measured at 14.4 Volts DC:
90 watts x 2 into a 4 ohm load
165 watts x 2 into a 2 ohm load
325 watts bridged into a 4 ohm load
Signal to Noise Ratio
> or = 110dB A-Weighted
Damping Factor:
>200
Maximum Input
8 Vrms
Frequency Response
20Hz-20kHz ±0.25dB
So, what should I do? Should I put one on one speaker and the other on the other speaker? Please give me your opinion.
thanks,
Adam
Old May 5, 2002 | 05:34 PM
coalyard's Avatar
Adam,
I might just get a lot of flack for this advice, but I would use the Optimus amp to power the subs, the MTX should be used for front stage, since it is a much cleaner and better sounding amp. After that, go out and buy a really good amp to power those subs when you can afford it.
Old May 5, 2002 | 08:52 PM
pimpinthaz28's Avatar
That is good advice, dont use the optimus on the highs, you will really notice the bad sound quality, but in the subs you wont notice nearly as much.
Old May 6, 2002 | 01:38 AM
HI92Z28's Avatar
Engine: stock 350 TPI
Transmission: rebuilt stock tranny, b&m shiftkit
I "would" use the MTX most amplifiers rate their amplifiers in 14.4 volts the Optimus is made by a cheap Taiwan company the MTX is rated at 12.5volts so if you car is running and with 13-14 volts you woill get more power (watts). Using the MTX you will get a louder and stronger bass with it verus the Optimus. To tell you the real truth you won't noticed the sound quality on both amps if you're driving the mids and highs with it.
Old May 6, 2002 | 02:42 PM
mrzud's Avatar
Hey me, do this: Sell the Optimus to your brother (it has 10% THD, really crappy), use the MTX.
Old May 6, 2002 | 03:12 PM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
i have that exact mtx amp and was using it for a few months on my 12" dvc. did a very good job at powering it. ran it at 2 ohm bridged and it never even got warm. nicely built amp and those specs are underrated. dont remember what my birth sheet said, but deffinately underrated by 5-10%. get rid of the optimus and find something on ebay. i got my blue thunder pro 752 for under $100 shipped. may be selling it soon actually.......
83 Crossfire TA
Car Audio
31
May 14, 2013 06:27 AM
FireInMe17
Car Audio
16
Sep 22, 2010 10:35 PM
HarmonyCamaro
Car Audio
26
Oct 19, 2009 08:07 PM
liteumup387
Aug 19, 2009 06:50 PM
