need amp suggestions
Old May 5, 2002 | 05:32 PM
caleb's Avatar
Car: 89' Iroc
what amp would you suggest i use, i am going to be using 2 Vega 124's they are 400watts RMS each, so i am looking for an amp that puts out between 600-800 RMS, so that i can wire them in parallel, and run them at two ohm.
I need suggestions like brands/models/#'s if possible,
thanks in advance
Old May 5, 2002 | 06:47 PM
rsxtcy's Avatar
try memphis, jbl, or phoenix. all three have great and clean amps. pm if you have any specific questions about them
Old May 5, 2002 | 06:50 PM
caleb's Avatar
Car: 89' Iroc
jbl
i was looking at a JBL powervalve 600.1 is the 600 the RMS or peak power?
Old May 5, 2002 | 07:25 PM
rsxtcy's Avatar
well it also depends on the ohms. at 2 ohms it is 600 x 1. at 4 ohms, it is 300 x 1.
Old May 5, 2002 | 09:30 PM
caleb's Avatar
Car: 89' Iroc
ya, i would be running two 4 ohm subs wirind in parallel, would make a 2 ohm load, so would that give me 300RMS to each?
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
gord327
Oct 3, 2015 01:25 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
raymondandretti
Sep 27, 2015 06:43 PM
