Wiring Subs
Old Jun 7, 2002 | 06:29 PM
82Z28_Camaro's Avatar
Wiring Subs
Can you wire a 2 Channel Amplifier to 2 dual 2 ohm impendance subwoofer? The specs on the subs are as follows :
Subwoofer Specifications
Rec. Sealed Box Dims: 0.50 cu.ft.
Rec. Ported Box Dims: 1.15 cu.ft.
Free Air Usage: not recommended
Sensitivity: 90 dB
Frequency Response: n/a
Recommended RMS Power: 900W
Peak Power Handling: 1800W
Impedance: Dual 2 ohms
Old Jun 7, 2002 | 06:53 PM
miked's Avatar
What kind of amp and how low of a load can you put on it. I would be careful. You could work an amp really hard with 2 ohm subs:
Go to rockfordfosgate.com, click on rftech, go to the woofer wiring wizard, select two subs and 2ohm dvc and it will show you the wiring configurations. Hope this helps.
Mike
Old Jun 8, 2002 | 01:59 AM
Audiman's Avatar
Is it a DVC, 2ohm a side or a 4ohm dvc.
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Ducati900ss
Sep 2, 2015 09:05 AM
Bryan F
Aug 27, 2015 07:28 AM
