Difference between Alpine Head units
Old Jun 11, 2002 | 10:09 AM
camaro6spd's Avatar
What causes a $70 difference between the CDA-D852 and the CDA-D855???? I am running all my speakers off Amps so i can get around 55 watts RMS at each one... this also brings up another question...The amp i am using to power the 4x6 plates and 5 1/4 in the rear puts out around 55 RMS...but when i get the 6.5 compents in the kicks then can handle up to 90 RMS....i was thinking about get a 2 channel amp puttn out around 75-80 RMS...is that a good idea or should i keep all the RMS the same for the main/compents?
Old Jun 13, 2002 | 02:21 AM
pronger44's Avatar
i don't know what causes the price differance but if i was you since i'm running everything off of amps i'd want 4v preouts or higher also i don't see a problem with running a bigger amp
Old Jun 16, 2002 | 02:55 AM
coalyard's Avatar
I would guess that one head unit would be AI net capable, and the other not. Just depends on your equipment, and what you want to do.
Old Jun 17, 2002 | 10:56 AM
camaro6spd's Avatar
evilstuie
Jan 9, 2020 08:29 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Cripley
Aug 17, 2015 03:35 PM
ZsTransAm
Aug 11, 2015 07:30 PM
