Boxes
Old Jun 11, 2002 | 06:40 PM
82Z28_Camaro's Avatar
Boxes
Im buying 2 10" subs, there stats say they can fit into a .5 - 1.0 cu. ft sealed box. I can either buy a .75 cu ft box or .65. What is the difference? Thanks
Old Jun 11, 2002 | 07:11 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
About .1
Basically, the larger you go, the smoother the response will be, but you'll have lower overall output. I hate boomy bass, and knowing how the car audio companies make their suggestions, I'd definately go with at least 1.0 cubic feet per sub if you want a good clean sound. If you don't care how it sounds but want to impress a bunch of teenagers with how loud it is, use a smaller box. .65 to .75 is so close that you'll probably be hard pressed to hear a difference between the two.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Ed1LE
Sep 30, 2018 09:14 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Zell1luk
Sep 29, 2015 10:36 AM
