Weird A$$ Noise Please Help
Old Jun 12, 2002 | 05:11 PM
ERICCAMARO's Avatar
Car: 92 camaro Rs
Engine: 305 tpi
Transmission: t-5 WC
I have a high pitched noise coming through my amp. it is from the alternator and as the rpm goes up the higher pitched it gets. it goes through my amp to the head unit and comes out my 6x9s
is there anything to filter this out?? will a different deck work. one with a 2v sub output?? if I put a equalizer in? or should i just get a new alternator??
Old Jun 12, 2002 | 08:59 PM
pimpinthaz28's Avatar
The sound that you aree reffering to is called engine noise. There aree a couple of things to check, make sure you are using good quality rca cables, if you use cheap ones then they get sound interferance from your engine. Another thing you could check is your speaker wire. A good speaker wire and RCA cable to use is rockford fosgates roit gamma cables. most likely it is your rca cables.
Old Jun 12, 2002 | 10:21 PM
deadtrend1's Avatar
and be sure you run the RCA cables seperate from the power cables. Avoid crossing over the transmission too, that will throw in some noise.
~Tim
Old Jun 13, 2002 | 08:42 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Also check to see how your head unit is wired for power. Some aftermkt brands actually have a filter on the power lead. Make sure you have a good ground and both wires have good connections.
Old Jun 13, 2002 | 02:18 PM
ERICCAMARO's Avatar
Car: 92 camaro Rs
Engine: 305 tpi
the noise only happens when i hook up the rca's on the amp. its weird I know its coming from my alternator. but how do i surpress the noise??
Old Jun 13, 2002 | 02:19 PM
ERICCAMARO's Avatar
Car: 92 camaro Rs
Engine: 305 tpi
ohh yea and everything is good. all the wires the rca's and i dont have the rca's running next to the power wire either.
db057
Jan 10, 2020 08:55 PM
gta892000
Aug 11, 2019 11:16 AM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
Randomtask2
Sep 7, 2015 05:06 PM
