Help! Wiring!
Old Jun 14, 2002 | 06:11 PM
mike1986fyrbird's Avatar
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
Help! Wiring!
Hey I got this Amp;
Concept CC-1002
4 Ohm Stereo Power (RMS): 100W X 2
4 Ohm Mono Power (RMS): 300W X 1
2 Ohm Stereo Power (RMS): 170W X 2
2 Ohm Mono Power (RMS): 500W X 1
Signal-to-noise ratio: 100 dB
Frequency Response: 5 Hz - 50 KHz
Total Harmonic Distortion: 0.05%
Input Sensitivity: 200mV-4V
Length: 11.82"
Width: 11.66"
Height: 2.37"
Continuously variable 0 - 18dB Bass Boost
Built-in continuously variable 18dB per octave crossover, from 50Hz to 250Hz
Platinum Connectors
Right now I have my 2 12" Sony Xplod Subs wired in Parallel, They are both 4Ohms, running at 2 Ohms. 250rms each.
They are in a big *** box in the hatch well, weighs about 100 lbs.
I want to put A Sub into the place where the spare tire is. This is for security and whatnot. So if I just hook up this sub to my Amp I will Probally blow it. Its rated 140RMS and I would be feeding it 300@4ohm mono. I don't want to chance it.
Ok so I guess my question is: Should I Hook up my 2 front Rockford 4x6's, or my Pioneer 6x9's along with my sub?
How would I wire this? Tri-Mode right? How do I do this? What rms will each speaker be taking?
Thanks,
Mike.
Old Jun 14, 2002 | 06:49 PM
Ok I figured out how to wire in Tri-Mode:
How many Watts will each speaker get?
Old Jun 14, 2002 | 11:55 PM
TFM4th's Avatar
Car: 87' Firebird
Engine: 2.8L
Transmission: Standard
Re: Help! Wiring!
one of my friends hooked up his 6x9's and sub up to his amp and blew the 6x9's......... soooo in my opinion thats not a good idea. not that im an expert or anything... i dont know if he wired em wrong or what, but no more 6x9's
as i recall he had it under the power rating on them... i dont remember what kind he had i know they werent pioneer...i got pioneer 6x9's and they sound great w/ out the amp, just get another sub
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
