crossover stuff
Old Jun 23, 2002 | 06:37 PM
mudaholic's Avatar
crossover stuff
ok so my headunit has built-in crossovers, and of course so does the amp.. if it makes any difference at all, what will be the better way to go? set the crossover on the receiver, set it on the amp, set it on both.. or it doesnt make any difference at all? oh yea, and why? thanks
Old Jun 23, 2002 | 09:02 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
It all depends on how good each xover is. I would use the xover with the highest db/octave ratio. For example, if the deck has an xover that's 12db/oct and the amp has 18db/oct, use the amp's xover. If they are the same, then use the deck's since you can make ajustments from the drivers seat. However, most decks have preset points were you can set the xover, whereas amps usually have a screw that offers infinte adjustments.
Old Jun 24, 2002 | 10:05 AM
deadtrend1's Avatar
I like using the amp crossovers rather then the head unit. Since I'm constantly working on my car, wheneveri need to disconnect the battery, I don't have to reset everything besides the clock ans stations.
~Tim
Old Jun 24, 2002 | 11:25 AM
mudaholic's Avatar
hmm good point.. so basically there wont be any difference in quality between the two crossovers?
Old Jun 24, 2002 | 11:44 AM
mcss383's Avatar
There very well could be!! What amp and what head? Not all x-overs are created equal....but most all of them are very good. As far as slope, generally the steeper the better, but let your ears be the judge.
I like using x-overs with the head....if it has good ones (like my P1R). That way, from the front seat, you can adjust and change things to sound the best. Its A LOT harder to do that when using the amps x-over. You listen to music, get up, go to the back of the car adjust and then go sit back down. Very hard to tell differences that way, it needs to be back-to-back. Now if you had a second person changing x-overs from the amps while you are sitting and listening, then it would work just as well as with a head.
Old Jun 24, 2002 | 01:18 PM
mudaholic's Avatar
jbl 1200.1 for the sub amp, alpine mrv-t420 (probably) for the components, and kenwood kac-x917 for the head.. its a pretty high quality/competition head unit, the jbl is just brute power.. im guessing that the head unit would be the cleanest way to do it for the sub.. not too sure about the alpine tho, from what i hear they have exceptional sq stuff.. any suggestions?
gixxer92
May 18, 2017 11:20 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
