Check Out These Subs!
Hey, I have two of these 10's that I picked up new on ebay for a good price but I never have had them hooked up. I have a Rockford 300s coming in the mail soon so how do you think they will be. What is your opinion on them THANX! Here are the specs:
Magnet: 160 oz. Double stacked Ferrite magnets
Frame: Chrome heavy gauge steel
Cone: Reinforced non press Paper
Surround: Oversized double thickness PHAT
Spider: Ultra excursion
Power handling: 400 watts RMS, 800 Watts Program (conservative)
T Yoke: Industrial design hex bolt retained, chromed, extended and vented
Cooling: Double Vented (T Yoke and Motor Side vents)
Voice Coils: 4 Layer Dual 4 Ohm High Temperature Kapton
Voice Coil Diameter: 2.1"
Nominal impedance: 4 ohms / per coil
DC resistance (Re): 3.2 ohms each coil
Frequency range: 20 Hz-1.5 kHz
Sensitivity
Fs: 40 Hz
QTS: .9587
QES: 1.0437
QMS: 11.7683
VAS: 26 L
SD: .0346 m
SPL: 85.73
Xmax:11.9 mm
Mounting Depth: 135 mm
Mounting Hole Dia.:250 mm
Net weight: 21lbs
Reported SPL Readings of 145 dB Plus !!!
Sensitivity
Fs: 40 Hz
QTS: .9587
QES: 1.0437
QMS: 11.7683
VAS: 26 L
SD: .0346 m
SPL: 85.73
Xmax:11.9 mm
Net weight: 21lbs
Sub's with 'specs' like that scream Jenson, Boss, Pyramid, Audiobahn and other flea market brands. While they aren't crap, they aren't all that great. But maybe yours will be good.
Hey if it does what you want it to, what more is there to ask for.
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: 700R-4
Maybe it's just you and that you have had bad experience with audiobahn subs, but from what i have heard(literally) and seen they are some mighty fine subs. Yes, they are flea market, entry level, may get what you pay for, equipment.
I had the ABC series components, 2 tweeters and 1 mid later I got fed up with their crap. I have an AW1200 and it gets decently loud and sounds like crap getting there (extremely sloppy). My friend also has/had the ABC comp. set, he also went through a mid and a couple tweets. Their amps are alright, they get the job done. He also had the dreaded '99 series Alum subs, got them replaced and the new ones haven't broke, but still are anything but impressive.
If you get them wholesale, you get decent equip for the money, you pay retail for them....
But hey, just my opinion and experiances with them.....
