...On the DVC Subject
Car: 1992 Camaro Z28 Convertible Z03
Engine: 383 SuperRam
On the DVC Subject.
I have the Phoenix Gold QX series amp its the one that will do 150x2 or 350x1
it does 350x1 at 4 ohms bridged
and I also have the kicker comp VR 12" DVC Sub.
Here is a link to their chart Kicker Chart How would I wire the sub to get max power.
simple answer please, red, red, black, black blah blah is what I'll understand. I'm not good with the series/parallel stuff,
I know what you mean buddy...I have 2 15' Fosgate Power DVC's, i didnt understand parallel and series either, i know you have Kicker products and yada yada yada, but actually, reading Rockford Fosgates wiring diagram wizard on their website helped me out...A LOT...
Hope if does for you too....
www.rockfordfosgate.com
the kicker chart is confusing, it has two things listed, its saying the kicker has 2 2ohm voice coils rite?
if they are dual 2ohms do from VC#1(voice coil) + to the amp then from the - from VC#1 go to the + on VC#2 and then from - on VC#2 go to the amp. should be 4ohms. you could check it too with an ohm meter if you have acces to one.
Josh
Josh
Ozz1967
Aug 16, 2015 10:23 PM
