Picking up a 92 rs convertible
Old Sep 30, 2002 | 01:25 PM
zimmstoy's Avatar
Car: 85 Iroc
Engine: 305 LB9
What are the speaker size and how many speakers are in the car stock?
ANy recommended configs for a convertible?
Old Oct 2, 2002 | 05:39 PM
highspeedfreak's Avatar
Do a search and you will find enough posts regarding this topic.
Old Oct 8, 2002 | 12:53 AM
iroc22's Avatar
If you have rear speakers from the factory, they'll be little 4" round ones. 6x9's work quite well in the back.
Old Oct 8, 2002 | 12:49 PM
LowStyle187's Avatar
There are 4 stock all together. There are 2 4X6 in the front under the dash and 2 6X9 in the back. There are many combonations that other people have done like adding kick panels and a pair of 10" subs in the back. But that should cover it.
Old Oct 8, 2002 | 02:00 PM
SHAGME's Avatar
Car: 1988 IROC-Z
Engine: 355ci TPI WORKED TO THE BALLS!
Transmission: 700R4 T-56 coming
email this guy
http://www.sounddomain.com/member_pa...rolet%20Camaro
Old Oct 9, 2002 | 03:37 PM
drop-top IROC's Avatar
Engine: 305 TPI (LB9)
Transmission: WC T-5
you cannot fit a 6x9 in the rear of a convertible w/o doing some major cutting. even then, I don't believe the depth of a 6x9 will allow the top frame to clear the sides when the top is in the down position.
Old Oct 10, 2002 | 06:33 AM
camaro6spd's Avatar
Yep, Kappa models will not fit, i tryed everything, and you can't remove enought material.
Old Oct 10, 2002 | 08:21 PM
ninety1TAgta's Avatar
In a coupe car, you need to aim the mids and highs at you. But if you dont they just bounce around the car till you pick them up, and by that time the highs (from tweeters) will have died.
In a convertible its priority number one you aim them at the driver or passengers because they wont reflect of anything top down, and they dont reflect well off of a cloth top. So kickpanels are more a less a must if you want good sound and these should cover the mids and highs decently. For the back, I would just get 1 way or 2 way 6 or 7s and either try to mount them facing the front with washers and some creative hammering or just aim them at the passengers. Then for the trunk it just depends if you like loud tight bass or bass that shakes the crap out of everything, like me . Probly a 12 or two would work nicely.
greg
Hotrodboba400
Dec 10, 2019 07:07 PM
fasteddi
Sep 10, 2015 09:32 AM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
