box structure
Old Oct 8, 2002 | 05:22 PM
White Ninja's Avatar
box structure
Fbodyaudio.com - here's the picture
Old Oct 9, 2002 | 07:10 AM
SHAGME's Avatar
Car: 1988 IROC-Z
Engine: 355ci TPI WORKED TO THE BALLS!
Transmission: 700R4 T-56 coming
Um a table saw works well or a miter saw, angle the 2 pieces or yes you could do it that way I suppose
Old Oct 9, 2002 | 07:52 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
If you're not 100% accurate with the length and of the angle itself, angled pieces wind up fitting like sh*t. At least with straight cuts, if it's a c-hair too long or too short, it'll still fit together and seal well.
Old Oct 9, 2002 | 08:12 AM
SHAGME's Avatar
Car: 1988 IROC-Z
that is very true just take time mesuring or do thast
Old Oct 9, 2002 | 11:51 AM
Jim85IROC's Avatar
Even if you take time measuring, if your cut is off by even as little as 1/8" it winds up fitting poorly. Not too many people can run a 4x8' sheet of MDF over a table saw without it drifting at least an 1/8".
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Ed1LE
Sep 30, 2018 09:14 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Zell1luk
Sep 29, 2015 10:36 AM
