How to port a ealed box.
Old Oct 17, 2002 | 01:42 PM
82Z28_Camaro's Avatar
How to port a sealed box.
What are the steps and tools needed to port a sealed box? I have the right box, I just need to get it ported. How would I go about this, and how big does the port need to be?
Colby
Old Oct 17, 2002 | 02:36 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Use a hole saw and stick the port in the hole.
Physically, it's that easy. Unfortunately, there's more to it than that. Just stuffing a port in your box isn't going to help. You need to find out what diameter and length port is reccomended for your sub, and additionally, what size enclosure your sub needs in a ported configuration... it's a different size than the same sub would need for a sealed application. This is information that your sub manufacturer should help you with.
Old Oct 17, 2002 | 04:43 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: How to port a sealed box.
Colby
smack it real hard with a hammar, boom. its now ported.
get a selection of pvc pipe 3in dia. 3in long 4in 6in 8in and try different ones till it sounds right. other wise you need a good speaker box program and put in box and speaker specs, then even your ears might not like it.
Old Oct 19, 2002 | 10:38 AM
BadMunky87TA's Avatar
yup, do it the right way or you are going to end up with horrible noise or nothing
Old Oct 20, 2002 | 01:38 PM
SuPeR SpOrT's Avatar
sorry to ask this but I am a dumbass, but what is a port..
Old Oct 20, 2002 | 01:39 PM
A port is an area where air can be released from the box.
Colby
Old Oct 20, 2002 | 01:43 PM
ah i c
Old Oct 21, 2002 | 08:51 PM
bubbakutz's Avatar
Car: 1987 "1991 Z" Sport Coupe
Engine: LG4
Transmission: TH700R4
does there need to be a port in a sealed box?
thanks,
bub
Old Oct 21, 2002 | 09:02 PM
Jim85IROC's Avatar
thanks,
bub
You might benefit from reading the articles in the tech section to get acquainted with the basics. There are many different kinds of subwoofer boxes: sealed, ported, bandpass and others. Learning the basics might help you better understand what you're reading in these threads.
Old Oct 22, 2002 | 09:44 AM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
thanks,
bub
I belive I depends on the sub that you buy. Some say they work best in sealed, ported or free air.
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Reid Fleming
Oct 10, 2015 09:56 PM
bplessy
Sep 30, 2015 12:14 PM
Zell1luk
Sep 29, 2015 10:36 AM
