Amp and regular speakers
Old Nov 9, 2002 | 11:46 PM
vrooom305's Avatar
Is it possible to connect an amp to the rear speakers of my Camaro? Will there be a difference in sound quality? I'm planning on getting new speakers and I don't want to get a sub just yet.
Old Nov 11, 2002 | 05:42 PM
elcamaro's Avatar
Car: 1984 Z28
Engine: 350 bored .030 over
Transmission: T-5 5-speed
Are they the original Delco's? If they are they will probably crap out really easily, unless it's a low power amp. I suppose it would really depend on the amp and how much power you're pushing. Cool pic.
Old Nov 11, 2002 | 05:51 PM
miked's Avatar
It would be possible but there are probably better alternatives. I don't know your current set up but you'd probably be happier upgrading your front speakers with the money and then getting an amp to run them and a sub. It would sound much better than amping the rear speaker.
Old Nov 11, 2002 | 09:26 PM
KsKid's Avatar
yipp, thats what i have going on right now. the rca outputs from the head unit run to the amp then from teh amp to the speakers. i have a 380 watt, 4 channel amp going to the rear 2 mb quart 6x9's. they used to run the front 2 4 inch clairions but since i got the pioneer head unit i put the 2 front speakers on that. more wattage for the sub... when i get one, anyone have a good one for sale?
Old Nov 12, 2002 | 07:50 AM
fly351's Avatar
Car: 1996 Camaro RS
Engine: v6
i would not recommend running your FullRange and Subs off the same amp.
Instead, if you plan on replacing your 4x6's, and 6x9's do that and wire them to a nice 200 to 500 watt amp. Then get another amp for your subs.
Also, if you plan on running 2 450 watt subs (just an example..) run atleast a 700 watt amp. 900 would be better.
-fly
Old Nov 12, 2002 | 07:24 PM
KicKeR's Avatar
If they are better quality speakers, then yes they will sound quite a bit better. Don't power them with an external amp if there stock. :nono:
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
wanext
Oct 6, 2015 12:18 AM
raymondandretti
Sep 27, 2015 06:43 PM
