8 gauge terminal cups
Old Nov 10, 2002 | 10:50 PM
DISTURBthePEACE's Avatar
Car: 89 Camaro RS
Engine: 2.8L V-6
Ok, so my alpine Type-R has "8 gauge speaker terminals" or sumthin like that. I'm assuming that means I can run 8g from the sub to the terminal cup, and from the terminal cup to the amp. But where do I find an 8g terminal cup? What if I went strait from the amp to the sub? would it get a better signal because it doesnt have to run thru the terminal cup?
Old Nov 11, 2002 | 09:05 AM
CaysE's Avatar
The speaker cup is meant to keep the box airtight, that's all. If you can find a way to run the wire straight to the sub from the amp while maintaining an airtight seal, go for it.
Old Nov 11, 2002 | 11:47 AM
caleb's Avatar
Car: 89' Iroc
Drill a hole in the box, then put the wire through, then seal it up with liquid nails or whatever:lala:
Old Nov 11, 2002 | 02:21 PM
CaysE's Avatar
That, too.
Old Nov 11, 2002 | 02:27 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
8 ga speaker wire is unnecessary. Just get some 12 ga or Stinger 10 ga speaker wire.
Old Nov 11, 2002 | 08:48 PM
Car: 89 Camaro RS
Engine: 2.8L V-6
I had heard somewhere that the bigger the wire=less resistance=more power to the sub, that and since it accepts 8g, might as well use it lol
Old Nov 11, 2002 | 08:57 PM
KicKeR's Avatar
I do not beleive that it will make the speaker sound any more or less cleaner. But yeah, its cool either way you do it as long as youj keep your box airtight, unless your running the wire through a port. - lmao -
Old Nov 11, 2002 | 09:13 PM
Car: 89 Camaro RS
Engine: 2.8L V-6
I've seen that done before, lol ghetto ****! lmao
Old Nov 11, 2002 | 10:26 PM
Huckster's '84 TA's Avatar
Car: 1984 Pontiac Trans Am
Engine: 5.0L
Transmission: TH700-R4
8 gauge is totally unnessesary unless you are running a few thousand watts to any sub. i believe it is more of a show thing. just stick with 10-12 gauge and that will be more than adequate.
Old Nov 11, 2002 | 10:34 PM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
yeah, 8ga is overboard. when i did my last box for my type-r, i used so extra 8ga i had just cause i thought it would look cool. but 10 or 12 ga should be more than enough.
Old Nov 12, 2002 | 12:56 AM
Car: 89 Camaro RS
Engine: 2.8L V-6
I to was thinking that 8g was more looks than power, but why would they put 8g speaker terminals on it? It would look bad to see 8g wire ran to a single sub, eh? If I have enough 8g left over around here I'll use it but if not I'll just go buy some 10g.
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
Luigytico09
Oct 1, 2015 08:46 AM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
