headunit
Old Nov 26, 2002 | 12:39 AM
Trans-Am 88's Avatar
headunit
keep blowing the "radio" fuse in the fusebox.. as soon as ignition is turned on
all the wiring in the back of the deck appears to be okay.. problem just started after a year of use... deck still ejects cd's..
any suggestions would be appreciated
Old Nov 26, 2002 | 08:57 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Re: headunit
Is this an aftermarket deck.
If so, just run a line from the batt.
I have to do it on my Alpine, otherwise my fuse will fry if I try to turn o nthe deck...
Old Nov 26, 2002 | 09:59 PM
SuPeR SpOrT's Avatar
acnt you just put in a higher tolerance fuse?
Old Nov 27, 2002 | 02:05 AM
mudaholic's Avatar
if the stock wiring is fused at 10 amps (thats what it is isnt it?) then you dont want to run more than that through it.. fire hazard. just run a new wire.
Old Nov 27, 2002 | 03:37 AM
Kj Rockz's Avatar
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Exactly.
I believe it is either 10, or 20, cant remeber right now.
You go higher than that, and fire follows....
ChevyLuva3
Car Audio
27
Mar 7, 2002 09:23 PM
jobryan26
Car Audio
32
Jan 5, 2002 11:34 AM
stuart69427
Car Audio
Dec 30, 2001 07:51 PM
PhantomTPI
Car Audio
Apr 23, 2001 09:19 AM
dhirocz
Car Audio
Apr 5, 2001 08:15 AM
