can i put a 1/2 din EQ with my sony 1 din headunit in the slot?
Old Dec 30, 2001 | 02:53 PM
stuart69427's Avatar
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
can i put a 1/2 din EQ with my sony 1 din headunit in the slot without a installation kit or will I still need one? i just bought a 1/2 din Pyramid EQ and was wonderin if it can go in their? if it doesn't have a kit will it move around. there is alot of space in there. i remember a long time ao when i removed the stock unit there was nothing surronding it and it stayed still. anotherthin if the units are stacked, then will they overheat?
Old Dec 30, 2001 | 05:12 PM
Flash84Z28's Avatar
Car: '03 S-10/ '87 Trans Am
Engine: mild 350
Transmission: TH350
It will fit, but i'm not sure if you need an install kit. I would think so, or else it would just slide back. The only heat concern is the tranny, HU's don't usually put out that much heat unless your running it full volume. So a good blanket to enclose the compartment would be good.
-Matt
Old Dec 30, 2001 | 07:43 PM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
right now i'm running a single din headunit with a 1/2 din eq. you need a kit. if you can, get one made by a company called Metra. these are the best kits and i know for a fact (because i am using one) that they have an adapter that allows you to use both a headunit and an eq. it also looks better because the units are more flush than when using just a single din adapter.
Old Dec 30, 2001 | 07:51 PM
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
thanx, ill try to do just that
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
69 Six Pack
Oct 5, 2015 07:51 PM
mustangman65_79
Car Audio
Sep 30, 2015 09:37 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
