Will this fix my problem?
Old Dec 18, 2002 | 08:51 PM
5.0L1992RS's Avatar
First of all, I did a search, but my specific question was not answered.
Right now I have a 75 amp alt, New battery, 560 RMS watt amp. I need to do something about the big power drain when the bass hits. I am looking to replace my alternator with this 160 amp one.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1875130628
Would this fix my problem? I would like to do everything possible without adding a cap.
Thanks,
-Kevin
Old Dec 18, 2002 | 09:48 PM
harry's91rs's Avatar
Car: 1991 Camaro RS
Engine: 3.1 V6 LHO
It should work, but a cap or a second battery would probably work the best. Also make sure your using thick enough wire. If its too thin it could be causing the big drain.
Old Dec 18, 2002 | 11:56 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
I dont think you need a cap or a second battery. 560 rms isnt that much power. A new alt should to the trick. If you are still having problem then I would go with a cap. But I dont think you will after you get the new alt.
Brian
Old Dec 19, 2002 | 12:39 AM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
make sure you get the right alt too. remember, some camaros were serpentine while others were v-belt. that one looks to be a v-belt setup... i've got a 100 amp one kickin around too if anyone's interested (v-belt)
Old Dec 19, 2002 | 09:15 AM
5.0L1992RS's Avatar
I really don't know the difference in the belts. Is the serp belt flat, where as the v-belt is in a v-shape? I just want to make sure of this.
Thanks for your help.
Old Dec 20, 2002 | 03:54 PM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
a serpentine belt setup is only a single belt, while v-belt has many (one accessory per belt). serpentine pulleys have many grooves, while vbelts only have one
Old Dec 21, 2002 | 08:59 AM
tyty49's Avatar
Car: 91 Maro & 97 Ram & 05 Roadstar
I ordered a alt from those guys semms like everything came and it works perfect. Even has a 1 year warrenty.
theshackle
Mar 5, 2017 06:37 PM
dyeager535
Aug 28, 2015 08:10 AM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
