Lcd
Old Dec 31, 2002 | 09:41 PM
rscamaro305's Avatar
Lcd
I did do a search but i couldn't find an answer. If i make a double din plate for my camaro and instal a dvd and a lcd screen will it work? I think it might hit the part of the dash by the rear defroster switch. Thanks for any help.
Old Jan 1, 2003 | 12:06 PM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
someone a long time ago accomplished the double din setup but i dont know about the lcd. you might have to check to see how far it swings up and back
Old Jan 1, 2003 | 01:47 PM
FLYNLOW92rs's Avatar
You can install a In-dash unit and a dvd player.....
You will need to make your own double din plate for the application though.....
As long as the in-dash is on the bottom you shouldn't have a problem.....
Old Jan 1, 2003 | 07:01 PM
So your saying i will probably be ok if i pu the LCD on bottom and the dvd on top in a double din setup.
Old Jan 2, 2003 | 12:28 AM
Camar92's Avatar
Car: 1986 IROC-Z
Engine: Vortec 350 with mild cam
Transmission: 700r4 Mild build
Axle/Gears: Stock
You should buy another lcd screen and install it in the flat part of the dash, would it work?
Old Jan 2, 2003 | 05:55 PM
I had a in-dash lcd unit in the STOCK location which actually sits a little higher up and i had to problems with it.....
You will have to move the screen down to insert/ejects cd's....
Why not save the money for the extra dvd player and just buy one with a dvd player in it??
Old Jan 3, 2003 | 03:07 PM
I might just save money and get a single unit. I also had an ides that extended the console up to the ac vents and has a headrest monitor mounted in it. I'm still in the planning phase so im still coming up with ideas thanks for the help.
anubiscougar
Car Audio
Oct 7, 2003 07:04 PM
My86Firebird
Jun 1, 2003 07:24 AM
12 Sec GTA
Apr 17, 2003 03:01 PM
EddieDellz
Feb 8, 2002 10:48 PM
tesla042
Sep 22, 2000 10:46 AM
